Is this how I get commanded lambda when not at part throttle/cruise?
Leave out PID.6010, The PE is already built into PID.6001 (On an E38)
Here's mine for E85, note the Stoich difference. Yours is fine for E10.
You don't even need "Commanded AFR" to determine commanded Lambda. Depending on what vehicle you are working on the EQ is either equal to Lambda or is the inverse of lambda.
Gen3 LS1 and E40 is 1/[PID.68]=Commanded Lambda
E38/67 etc is [PID.68]=Commanded Lambda
For whatever reason the newer stuff reports EQ as Lambda.
James Short - [email protected]
Located in Central Kentucky
ShorTuning
My 2012 E38 reports PID.68 as Commanded EQ Ratio. Might have to divide it into 1, won't be able to test until spring. Bee is in hibernation. I'll add it to the table.
You may want to take a double look at that.... all of the E38's I've done are not true EQ and are in fact lambda. If when you go into PE the reading on Commanded EQ goes below 1.00 then it is lambda. If it goes above 1.00 (like Gen3 LS1's and E40's) then it is truly representing EQ and not lambda in which case you would need to take the inverse of it to get Lambda.
ShorTuning
whats the benefit of these methods over the command afr? Will it display faster with less calculation?
