Results 1 to 3 of 3
Thread: why does my sisters oem tune have so much knock
    it seems like alot for a 100% stock truck
    KATEs Truck.hpt
    kates log.hpl
    2002 Z06-408LQ4 583RWHP 496RWTQ on E85 / 919RWHP 895RWTQ @300 shot
    13,576
    I didn't see anything abnormal.
    Random bits of KR at low throttle % and low loads tend to be common in my eyes for 5.3 trucks. My buddies 2011 gets tons of random blips while bouncing in and out of DoD and just crusing around town.
    I'm sure if the truck was running 91+ octane, the WOT kr might drop a little bit but some fine tuning could get it closer to zero.
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    That looks like real KR to me as it is happening under load. Even with the KR your still running ~26 degrees of timing which is good for an LS motor. Even the best of tunes with good gas usually dont run more than ~28 or so. Pull out the timing where its knocking plus a degree or two and i bet it runs even better.
    Remember its better to run several degrees less than KR point vs. one degree too much as your fighting the cylinder pressure.
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
