Results 1 to 3 of 3
Thread: Injector question
    Jan 2014
    Waldorf MD
    19
    Injector question
    Hello
    Does anyone know where I can find injector specs (flow vs kpa, offset, etc) online?
    Advanced Tuner umrjmac's Avatar
    May 2010
    Lenexa, KS
    266
    That depends on the injector that you're chasing data for. There is a fair amount of information available in the forum. You can also usually get pretty good data from the tune repository, particularly if you are looking for stock injector metrics from a different vehicle (LS9 injectors, for example). If you pull data for non-stock injectors from the tune repository, I would also pull a stock tune for the same vehicle and compare data...if they only adjusted the flow rate and left everything else alone then I would keep looking. Also some manufacturers publish their data on their websites (Injector Dynamics comes to mind), although that seems to be pretty few and far between. Finally, Greg Banish's first GM DVD comes with injector data for a handful of common injectors all converted to GM units.
    Kenne Bell Supercharged 2003 Corvette Z06
    Jan 2014
    Waldorf MD
    19
    Cool. Thanks!
