so 80 enable and 6 disable for PE kpa?
thanks so far
thanks so far
[email protected]
10 it is.
While you are at it, please double the Engine>Torque Management>Supercharger>Boost Control>Desired table. Looks like TM is pulling some timing when you are in Boost. And yes you math is correct, 15 lbs of boost.
Thanks,
Ed M
[email protected]
here's the latest
should I take out some timing?
Yes, 92 octane you said, right? Try this table. When you load into HO table, copy to LO table and multiply by 50%. Let me know if sluggish or any area's where you think you may have lost some jump!
Ed M
spdmn work 7 timing table.xls
[email protected]
ok will do, thanks
timing adjusted
also my wide band is mounted on bank 2 after the cat. Don't know if I had mentioned that anywhere
Not the best place for it. Can you move in front of the cat? Is there a bung in your headers for the WB?
Any logs from tune 7? How is the car running up to now as far as your perception?
Ed M
[email protected]
I'll will have some logs tonight (Hawaii time). I'm still running the full factory exhaust. I had headers on and took them off when i moved here.
The car seems to run well. Just was concerned about the knock. I have not been beating on it until the last few logs.
pm log, power seemed to be down alittle
not understanding why I'm seeing knock with so little timing
If it's any consolation, I'm having a similar issue with my ZL1.
Knock is occurring at low speed and rpm usually in 1st and 2nd gear. Pulling lots of timing in the 1600-2800 rpm range hasn't helped.
Mods include a cold air intake, 10% overdrive crank pulley (making ~ 12 lbs of boost) and ID 850 injectors.
Current tune is MAF only which I suspect is part of the problem.
I've been closely following your thread in hopes of finding a resolution.
Yeah I'm learning as I go
I am working a new timing table.....
Ed M
[email protected]
OK hope this should do it......attached is a new timing table which removes a degree or so in the 1200-1400, adds a degree or 2 in the mid power area's to try and put the "jump" back into the setup. In addition I would like to desensitize the Burst and Knock sensors a little to see if real knock or not.....
Engine>Spark>Knock Sensors>Knock Sensor Level>Initial Level from 120.0195 to 170 and Min Level from 50 to 125
Engine>Spark>Burst Knock retard>V8 mode -- set .012g/cyl to 0, set .018g/cyl to 0, set .024g/cyl to 1, set .030g/cyl to 2, set .036g/cyl to 3 and set .042 g/cyl to 4....
work8 new timing table rev a.xls
Ed M
[email protected]
ok sounds good, thanks!
