Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 153
Thread: Help with first HP Tuners file
  1. #41
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by spdmn75 View Post
    not seeing the zone boundaries button anywhere
    They are in the Dynamic tab....please look at my post #36 above. I showed you where all the tabs were.
    Ed M
    [email protected]
  2. #42
    Mar 2007
    Florida
    3,772
    does this look like its setup right? I was able to do ltfts yesterday and get them down to 5s from -18s
    Does what look like it is setup right?
    Ed M
    [email protected]
  3. #43
    Sep 2013
    Hawaii
    93
    I see its under the dynamic tab for other vehicles, not mine, so now what?
  4. #44
    Sep 2013
    Hawaii
    93
    ok got it to show now. for some reason it only showed the first 2 boxes
  5. #45
    Mar 2007
    Florida
    3,772
    Did you change the view to Advanced? per above as well?
    [email protected]
  6. #46
    Sep 2013
    Hawaii
    93
    it wont let me right click on the tab
  7. #47
    Mar 2007
    Florida
    3,772
    Not the Tab, the box's that say Zone RPM and Zone MAP Boundries....
    [email protected]
  8. #48
    Sep 2013
    Hawaii
    93
    that's what im clicking on
  9. #49
    Mar 2007
    Florida
    3,772
    Are you seeing this....
    [email protected]
  10. #50
    Sep 2013
    Hawaii
    93
    ok got it imported after 2 trys and a .net issue. it does keep closing vcm editor. now which table format? ls3 2.5bar?
  11. #51
    Sep 2013
    Hawaii
    93
  12. #52
    Mar 2007
    Florida
    3,772
    Yes.
    I have problems with shutting down the VCM as well at times. When that happens you can leave the BC Equation screen open (don't hit import) and copy/paste each of the tables from the tune file manually.
    [email protected]
  13. #53
    Mar 2007
    Florida
    3,772
    OK looks like you got it imported and the VE table generated. This represent the "Primary VE" table that the Tuning School talks about. At the bottom of the table is the MAP and RPM axis values to put in your histogram.
    Ed M
    [email protected]
  14. #54
    Sep 2013
    Hawaii
    93
    ok working on the histogram
  15. #55
    Sep 2013
    Hawaii
    93
    ok its not creating the histogram. does this look right?
  16. #56
    Mar 2007
    Florida
    3,772
    It is better to use the PID's instead of the sensors, more accurate. Use the RPM and MAP PIDS similar to how you selected the sensor ones. Don't forget you gave to generate an AFR error PID to load into the General & Plot. Lastly make sure you have selected all the required PID's into you .cfg file. Includes the sub pids needed to calculate your AFR error.
    Ed M
    [email protected]
  17. #57
    Sep 2013
    Hawaii
    93
    ok changed to pids, still not accepting it
  18. #58
    Mar 2007
    Florida
    3,772
    what did you input in the General & plot tab?
    [email protected]
  19. #59
    Sep 2013
    Hawaii
    93
    nothing because it said to leave the primary blank
  20. #60
    Mar 2007
    Florida
    3,772
    Not Primary showing here, click the General & Plot tab and it will open the area where you need to define the AFR err PID you generated.
    [email protected]
