I know 2 & 3 bar custom OS that can be bought.
But can a custom air flow Hz be bought that goes pass 11.500 Hz on the Mass Air Flow area?
Most people will just get a different throttle body and MAF sensor to deal with that.
Atleast anyone with a 3800 motor.
Just a question to keep a open mind open.
Is that a yes or no on my question?
Or may light be shined to my question in case someone ask me, I like to be able to support HP tuners if I'm ask this question out side this site. Cause there are people that still never heard of HP Tuners. At least from what I'm running in to.
Buy a 2cent resistor and solder it on the maf, or buy a mini afc.
For the most part no. There are a few E38/E67 custom operating systems that extend the maf table but thats the extent of it.
x2 on bigger TB, use a larger diameter pipe (4") and a differant MAF and rescale accordingly.
The larger pipe is the key, as the same amount of air flowing in the larger pipe will flow slower, which will make the MAF read slower. This will require adding more fuel, as the engine thinks its getting less air and its actually getting the same amount of air, just at a slower speed over the MAF.
2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
This one is pretty user friendly if you go the mini route...
http://shop.zzperformance.com/store/...ontroller.aspx
I say bigger tube and a new MAF is the way to go, but if you want the mini that is the one to use imo
2000 Trans Am WS6
