Results 1 to 10 of 10
Thread: OK... Noticed a lil problem with my DHP 1.0
    Jan 2014
    Waldorf MD
    774
    Here is a screenshot of the DTC section of the VCM in my GTP (its a DHP 1.0)
    It doesnt have ANY DTC's listed at all. Yeah fun and all but from the way it looks, I will NEVER know when anything goes wrong! So here is what I wanna do...
    I have a STOCK tune file. Can I copy over differences from the DHP 1.0, change the VIN, license the file and then WRITE ENTIRE? Is so, is this the CORRECT order?
    Thanks!
    13,565
    I'd just get a new 98-00 GTP computer if was me.
    Then use some stuff off the DHP and copy it over.
    I'm curious as to what DHP did to their PCM back in the day before they went outta business, mind posting the file.
    Jan 2014
    Waldorf MD
    774
    Here you go 5FDP...
    And thanks Planethax, I will try that. I figured I would have to flash a stock file first. Does changing a VIN cost credits? Im new to this HPT thing and Im still searching my behind off...
    Thanks again guys!
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Yes it would end up costing you additional credits to flash in a good file. Might be best to just start with new pcm depending on your situation.
    Jan 2014
    Waldorf MD
    774
    So I know that licensing the file will require 2 credits. I don't mind that. But if I change the Vin on the file BEFORE I write entire, will it cost MORE credits?
    HP Tuners Support
    (foff667)
    28,265
    I'm not sure if you'll be able to even change the vin without the year/model license. My advice would be to contact support once you are ready to fix the pcm and let them help you through things. Make sure to refer to this link/post.
    Jan 2014
    Waldorf MD
    774
    Ok so if I flash this stock file that I have, which VIN will I have? The VIN that's in the PCM (which is correct) or the one that's in the file?
    HP Tuners Support
    (foff667)
    28,265
    vin in the pcm if I remember correctly, with v6's you need to go through the vin change procedure outlined in the help file so theres a good possibility you'll need the year/model license.
    Oct 2011
    11
    Message me, I can help with this!
