Thread: Need to reduce power
    Aug 2011
    kansas city
    15
    I'm sure this is the opposite way most people are going but I have a car in a NASA TT class that is based off power to weight and I'm over. I don't want to add more weight and need to loose only about 25WHP based off my last dyno which was just after break in. The car has a few races on it now and I'm sure has broken in some so I need another baseline.
    So I'm wondering if it's safe to just pull a degree or two of timing in the WOT region of the map to get me where I need. I can't think of any reason it would hurt since OEM was around 18* and I'm now around 22* and I think 20-21* will let me hit my target. I just want to make sure I'm not going to toast a valve or something I didn't think of.
    Actual specifics: They car dyno'ed 452rwhp and I need to it to be near 425 rwhp. This was on 91 pump gas with ~10:1 SCR.
    Thoughts???
    Nissan 350Z ls2 swap
    Mods:6.0L, L92 heads (light porting), FTI solid roller cam: 236/247*, .636/.646, lsa115, 1-7/8 long tube headers, ls3 intake manifold, T56 magnum manual transmission.
    600Z build pics: http://s483.photobucket.com/albums/rr191/QTB33/Z33/
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    You can absolutely pull timing or add fuel to get where you need. You won't hurt anything unless you do either one to an extreme.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Aug 2011
    kansas city
    15
    Okay thanks. I didn't think that little was a big deal but better to check with a few pros before hand.
    Sep 2008
    1,668
    Also, if you pull a degree of timing and it takes too much power out...you might get away with a different AFR to bring the power back up a little where you want it to be.
    2023 Durango Hellcat
