Results 1 to 6 of 6
Thread: TCM and gearbox issues --- frustrated
    hi all,
    please help - I have an LS3 with ECU which came out of a 2007 Silverado with O/S ID 12614088 and the ECU is calibrated for an auto box - but I have a manual box installed - and I just cannot program the ECU at all -- no changes are accepted.
    I keep getting an error "transmission mismatch TCM detected" I am trying to change the gearbox to a manual one and then start tuning ...
    anyone have any ideas?
    Dec 2009
    1,084
    do a re-read of the Pcm without the TCM attached and see if that works.
    Quote Originally Posted by planethax View Post
    hi there
    thanks a lot - but there is no TCM -- its a manual gearbox with Silverado ECU --
    Tuner in Training Longslyde's Avatar
    Jan 2012
    St. Cloud, Minnesota
    38
    In some of the OS's, there was a PID for the gearbox under the Engine info. It had the options for Auto or Manual and you had to select Manual. Not sure if your OS has the option though...
    2017 GMC Sierra Crew Cab
    Forged 6.2L Flex Fuel Tuned
    Twin Turbo 13 PSI
    8L90E Transmission
    3.23 Gears
    Yes, it runs on E85 too and LOVES it! ;D
    Dec 2009
    1,084
    Quote Originally Posted by Rocket View Post
    hi there
    Do a fresh read of the Pcm and try that.
    thanks, gents -- only way to solve this one was to replace ECU ----
