Results 1 to 9 of 9
Thread: VCM not found on 1999 camaro
    Dec 2010
    Fort Worth, Tx
    104
    I cannot connect my HP tuner to the OBDII port…
    it shows an error
    cannot connect to VCM
    I verified continuity to the port from the BUS PCM pin out to #2 on OBDII plug
    I verified it is receiving a 12 volt signal. it has power.
    grounds check out ok.
    radio fuse check out ok. actually placed a new one there.
    HPT plug lights up showing it has power.
    check it with a 12v test light and is working as well.
    the car currently has a no spark condition I am trying to diagnose as well if that makes any sense. see below about what I have checked
    Im at a loss….
    car actually started about 3 months ago. I have not started it and now that a I want to move it to the garage it will not start nor connect to the HPtunner
    I have been chasing a no spark condition on my camaro for a while.
    I have done a lot of troubleshooting and everything is coming out fine
    things I did
    verified the PCM is grounded
    verified the PCM is receiving 12 v
    verified its sending a 12v signal to the fuel pump.
    new ignition relay, swapped it out with another one already as well
    checked the coolant temp sensor. appears intact. I took it out and inspected it as well. no codes can be read bc I cannot connect my HP runners to the car. see below for this issue……...
    all grounds check out ok
    battery fully charged.
    coils are receiving power at the plugs on both sides
    PLEASE HELP me…….
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    could be a vpw chip issue, try connecting your hptuners interface to a similar gen 3 car or truck to see if you have the same issue, if so its almost certainly a obd2 cable or vpw chip issue.
    Dec 2010
    Fort Worth, Tx
    104
    I try connecting to my TBSS w no problems. Do I need to specifically try a gen 3car.? If so. I'll try tomorrow.
    As far as I know the above is all u need to be able to connect right?
    HP Tuners Support
    (foff667)
    28,268
    Yes, gen 4 is can, uses a different chip. Gen 3 is vpw
    Dec 2010
    Fort Worth, Tx
    104
    So what would I have to do in order to fix that if that was the case.?
    HP Tuners Support
    (foff667)
    28,268
    You would contact support via email and we will instruct you.
    Dec 2009
    1,084
    Does the MIL turn on during bulb check?
    Try a cheap OBDII reader to see if it will connect and pull codes.
    Dec 2010
    Fort Worth, Tx
    104
    Figured it out. I took the pcm to my buddy and hooked it up to his ta. Same deal. Csnnot locate vcm. Hp tuners worked on his pcm w/o issues. I have a bad pcm.
    Now. Where can I get a hold of one for a 99 camaro w the A4 transmission?
    Jan 2011
    5
    Try tunebyfrost of something like that. Google it. Also LSXpowertuning.com
