Results 1 to 6 of 6
Thread: Camaro E38 PCM EGR wideband
    Jan 2014
    12
    Has anyone tried this? I have searched and searched and don't seem to be able to find a solid answer on what pin I would use on the PCM. Maybe 47? Is that an accurate way to log AFR, or should I just go ahead and buy the pro? Wideband in question is an lc-1.
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Welcome B-Rad, saw your post on Camaro 5 as well. When moving to the LSx platform I upgraded to the Pro and use the analog output from my Lambda gauge into HPT Pro. Second bung welded into Bank 1 header.
    Jan 2014
    12
    Thanks, I will probably just go ahead and get pro then, it seems like not many people use it that way. Do you think it would be a problem to just remove both post cat o2 sensors and put the Wideband in place of one of those? I'm running castles anyway so they will have to be turned off.
    Jul 2009
    2,305
    Should work, just a tiny bit more delay at idle. You'll be better off with the pro in the long run.
    Feb 2006
    Canada
    1,958
    Anything that has a 0-5v reference that is supported by the HP Scanner can be used. Ac and EGR have always seemed to be the choice when you don't have the pro to hook up. The pro is faster. So, not only will you loose going to the second 02, your going to loose using a sensor signal as well... kinda double whammy in your case if you go that route. If your going to use the basic and patch a sensor for signal, I'd spend the few bucks and get a bung where you need it, closer to the manifold
    2000 Trans Am WS6
    Jan 2014
    12
    I think I am just going to go ahead and get the pro. Seeing as I am a beginner and will probably need to post logs and get help, it will probably be beneficial to be able to log AFR properly.
