Results 1 to 7 of 7
Thread: High Overlap Tuning and Vaccum
    I spoke with another tuner today just having a general conversation and he said that anything under 110 LSA will need a vaccum pump if tuning EFI. I saw some guys tune a 248/252 112 which is around 27*+ overlap and tuned on EFI per HPtuners. I was thinking about running a cam in the 230's with 21* overlap. My question is since the overlap is less than the 248/252 112 cam, is it possible to still be able to tune EFI per HPtuners? Or do I have to go to a carb?
    Can you run around 20-25* of overlap EFI?
    Would it make enough vaccum or would I need a vaccum pump?
    Sep 2011
    Jax, Fl
    216
    You are fine, the bigger cams aren't easy but IMO fuel injection gives you way more control of them than a carb.
    2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
    L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
    JHP V2 I Powdercoated Black 18s I Kyne Splitter
    2001 GTP I Stock DD
    You will be fine
    I tuned 38* with stock engine before it drives fine
    Quote Originally Posted by wesam View Post
    You will be fine
    Did you run into issues with vaccum with your power brakes or A/C?
    No there was no problem in brakes or AC
    Quote Originally Posted by Kyne View Post
    Thank you both
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    I regularly do stuff with over 30* of overlap with no issue.
    http://www.dsxtuning.com
    Just say no to bull s***.
