GM CAN2000 replaced with VCM Scanner ?
Hello,
My tuner uses the GM logger called "CAN2000" but would like to buy VCM Scanner instead.
Can I log this PIDs my tuner needs but using VCM Scanner instead ?
PID Parameter Name
4 Calculated engine load value
6 Short term fuel trim B1
7 Long term fuel trim B1
000B Intake manifold absolute pressure
000E Spark advance cylinder 1
10 Air mass flow
11 Absolute throttle position
003C Catalyst temperature B1 S1
43 Absolut load value
44 Commanded equivalence ratio
004C Commanded throttle position
000C Engine speed
1A2D Actual engine torque at crankshaft
1175 Actually executed engine torque request
12D9 Ignition retard knock control cylinder 1
247C Raw Driver Inteded AXLTRQ
2429 AXLTRQ actual
242D Comm Immed AXLTRQ
2434 Driver Intend AXLTRQ
2438 Comm immed ENGTRQ
244D Max Pred. ENGTRQ Capacity
2449 TRQ based Calc Eng Load
328A Desired turbo charger boost pressure
328B Turbocharger A Wastegate Duty Cycle
Thank You
MT
PD: I just found this post should be in another section.. Any admin that can move it to "VCM Suite Product Info"?
