Results 1 to 16 of 16
Thread: need help swap08 truck engine e38 ecm truck starts for 2 seconds and dies
    south texas
    19
    i swaped a 2008 ly5 engine and tranny and ECM from the same pic up into a older pic up i flashed the ecm with my vcm suite software and managed to turn engine on ! it will spark up and stay on for 3 seconds and shuts off ... any ideas as to what else needs to be done to the swap or ecm to make this work im losing hair and turning gray by the minute ........ thanks in advance ( fairly new to hp tuner software ) baby steps with it !!!!!
    Dec 2009
    1,084
    Have you disabled 2 Vats/starter checks and the corresponding dtcs?
    Posting your file will help.
    south texas
    19
    disabled vats and starter dont know the steps for the dtcs? would like ur help (baby steps with software) i trying to up load file
    south texas
    19
    heres the file sorry i took so long new to this whole awsome forum world
    Dec 2009
    1,084
    Try setting P1631 to 3 no error reported and go to system and disable starter diag and report back.
    south texas
    19
    does it need a write entire for this
    May 2010
    Behind the wheel
    272
    Quote Originally Posted by j.garza View Post
    No, it should not.
    south texas
    19
    anything else you guys might remove from it ? im not using the original fuel pump going with external pump would this have any affect in the dtc's and MIL
    south texas
    19
    i have done what you guys have indicated an no success anything else ? !any more ideas
    Dec 2009
    1,084
    Next step is more Diagnosis.
    Check to see what is missing/cutting out.
    Fuel pressure or Spark or Injector pulse. (or a combination)
    Also log all Vats ifno to see if it is going into theft mode.
    south texas
    19
    the injector pulse dies out
    Oct 2009
    229
    Add the " current firing cylinder " to your scanner. If it never moves your crank sensor failed , I had this issue when I swapped an lq9 into my 96 like 6 years ago.
    Oct 2011
    7
    When I installed a 08 PCM on my 07 truck it would turn on and die, I had to disable VATS, P0513 and P0633 because the key dont match the PCM
    Dec 2009
    1,084
    Quote Originally Posted by tamagacho View Post
    I thought he did when I first looked at file but I guess I looked wrong.
    Set those dtcs to 3 as well.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,213
    You must do a write entire when making changes to the VATS or starter checks.
    Russ Kemp
    south texas
    19
    guys thanks for all your help and opinions truck has finaly stayed on i followed all the dtc instructions from each of you ....... still strugled for about two days ...and no results ...... i decided to upload a 2008 stock file all over again and started from the begining ..... removed vats ,dtc, starter dig, etc ... and truck fired right up and stayed on .... the only diffrence i notice in the scanner was the MAP was readind 200 in the old diag. ....i have gotten the 2000 oem cluster to work ... the volt,rpm,oil presurre, done, ...still strugling with fuel gauge , eng temp, VSS any ideas remember i swaped all 2008 components into a 2000 pick up !
