I have a 1998 S-10 Blazer with a 4.3 5-speed. It has a issue when in gear with holding the RPM's up after you let off the throttle for a few seconds the it decelerates as normal. I tried changing the follower decay numbers from in the 70's to high 600's. This seemed to help but did not fix the issue. Do I just need to raise the numbers more or is there something else I need to do. I attached a log and config
1998 Blazer Tunable 12-19-13.hptBlazer 12-28-13.hpl
