Results 1 to 5 of 5
Thread: MAF Power limatations vs. restriction?
    I read somewhere that Greg Banish said the stock 85mm with a screen MAF is good to about 500BHP without it being a restriction.
    Should I use a card style or descreened MAF for 570-600BHP?
    Will a stock 85mm MAF with a screen support 570-600BHP? Or should I descreen or go SD?
    Motor is a 6.1 in a 99 f-body.
    Dec 2011
    San Antonio, TX
    319
    I wouldn't descreen... It just smooths the airflow to going through the MAF so that it can get a better reading. Some do it and have no issues while other do have issues. A card style is much faster and accurate than the older ones in the housing. If you're thinking about upgrading, go with that.
    Aug 2009
    Calibrating
    3,373
    Using a 5inch tube on a double scaled 50% tune with a card style maf
    Nov 2002
    Central Florida
    2,503
    The stock 85mm MAF is good to 459g/sec @ 12kHz. Actually
    less g/sec than the 75mm Camaro / Holden MAF.
    The screen costs you at the big end, this is measurable.
    Look at your MAP readings with a screened and descreened
    piece, if you care to. It's given me no problems, running
    an 85mm descreened Delphi truck MAF and a Z06 table.
    But people with bent intake tracts can see problems with
    fidelity.
    How much HP that 459g/sec gives you depends a lot on
    motor efficiency and state of tune.
    Quote Originally Posted by jimmyblue View Post
    fidelity.
    I have a straight shot from the filter to the TB about 12-14 inches.
    Do you get higher Map readings with it descreened? If so what does this tell me?
    I m just trying to learn and connect the dots. Thanks.
