Results 1 to 3 of 3
Thread: PCM template or base JKD7 info ,please help !
    Jul 2012
    2
    I am currently tuning a 2011 gt500 with sct pro racer and the only strategy for my base tune is JKD7 , can anyone tell me what this processor code is for bc I cant find these letters anywhere on my PCM ,and I feel like it is for a earlier year car and is causing me lil problems that just wont go away , mainly a surge when pushing the gas about half way , rite at tip in . also keep seeing a lean spikes at every tp but wot . Can anyone shed some light on my situation ? 2011 gt500 2.9 whipple 3.25 upper,cfm twin 67mm tb, jlt 123mm intake , I D 72 lb injectors, no cats .
    Oct 2007
    Crawfordville, FL
    2,410
    JKD7 is a 2011 PCM code. Definitely sounds like a tuning issue.
    Dec 2005
    222
    The part throttle surge is most likely a tuning issue. With a bigger TB, it may be due to the FFTA/ETA correlation and you may be able to soften the surging from calibrating those tables more closely. With the bigger blower, it can also be in the TQ/Inv TQ correlations. You really need to be within about 10% on the TQ/Inv Tq so try tightening up your accuracy on those tables. Also, don't go wild on the driver demand...that'll add to the problem.
    Jeff Chambers, Owner
    CRT Performance, LLC
    349 Cleveland Road
    Norwalk, OH 44857
    Ph: 419-668-4151
    Fx: 419-668-4643
    Performance Parts, Service and Dyno Tuning Specialists
