maybe its a dumb question , but what section stands for what? i mean engine , trans, fuel etc
especially segment 4 & 6
Attachment 42173
Attachment 42173
whats wrong with this forum?? does anyone still use it?
Im new here too and I believe that people dont want to fix your problem but will help
Impatient much?
I believe those are the GM OS id #'s for the PCM as well as the body control module, ABS module, VATS module and etc. I know the segment 1 is the PCM. Don't know which is which beyond that.
Bryan
Hello Dexter.
I do not have an answer for your question.
I will be watching this one because I will probably be doing a fuel segment swap in the near future.
Ricardo
1996 A4 FBody with LS7 swap
^ hahaha, i was expecting your post .lol yes #6 is the fuel segment ...
already shoot an email to support.
got it.
Segment 1 : Operating system
Segment 2 : Engine calibration
Segment 3 : Engine diagnostic calibration
Segment 4 : Transmission calibration
Segment 5 : Transmission diagnostic calibration
Segment 6 : Fuel system
Segment 7 : System calibration
Segment 8 : Speedometer calibration
The easiest way to remember this is to look at the editor, the order of which each segment is listed on the top bar is the order they are in under the calibration details screen....
OS, Engine, Engine Diag., Transmission, Transmission Diag., Fuel System, System, Speedo
Same goes for the calibrations, each of those sections edits that particular segment so when you do a segment swap you are basically copying everything from the downer segment to your file. This is why when doing segment swaps the main operating system must match so that the parameters are addressed correctly.
James Short - [email protected]
Located in Central Kentucky
ShorTuning
