Results 1 to 17 of 17
Thread: Ford injector data to GM format conversion spreadsheet
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    I've been holding out on this for a while, but figured it's time to just let it out there. I've only mapped a few sets already, but left the green fields editable so that anybody can take any set of Ford data and enter it in to convert it to GM format. I actually had to delete a few sheets of pre-mapped injectors due to file size limits on the forum.
    The methodology is fairly simple behind all of it. Beyond knowing how the two formats relate (and the algebra behind the conversion from Ford to GM format), I used linear regression to map the relationship according to the various GM table break points. For flow rate, I actually use power regression because it generates a much better fitting curve (I also generate coefficients for the relationship because Bernoulli's simplified square root formula just doesn't line up right).
    I think I hit all the major table formats. If the one you need isn't listed, pound sand, because I'm not editing it. Lol.
    Note: You will notice that data above and below certain voltages in the offset table may look goofy. When looking at the visual representation of the offset table, the data will actually curl up in the higher voltages. This is because the generated data is not extrapolated according to a typical trend, but rather follows the coefficients generated for the voltages from 6v to 15v.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Sep 2011
    Jax, Fl
    216
    You are the man! I've seen you hinting at how to do it, thanks for sharing this with us. I would like to compare it to GB data now.
    2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
    L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
    JHP V2 I Powdercoated Black 18s I Kyne Splitter
    2001 GTP I Stock DD
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by Kyne View Post
    It differs from his data for sure.
    Sep 2011
    Jax, Fl
    216
    I think that came out wrong, I meant compare not to see that they are different but how they differed.
    2001 GTP I Stock DD
    Thanks Dave, always helpful!
    2006 CGM A4
    Tuner 07MontRedcp's Avatar
    Jan 2007
    Arizona
    187
    Do you happen to have a sheet for the SD 60. I have the GB CD and would like to compare.
    Thanks,
    BJK
    APS TT 630 rwhp/654 rwtq @ 9 psi
    '07 C6, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, LG GT2 Coilovers, Autometer Cobalt Fuel gauage, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system. RX dual valve catch can.
    Mar 2008
    St. Louis, MO
    4,859
    Go look up the Ford data and apply it. The forum limited me on file size, so I had to delete sheets.
    Jan 2007
    Arizona
    187
    Yeah, I used to have the ford data that racetronixs put on their site, but I dumped it when I got the GB DVD. Now I'm having trouble finding it on the net. I'll come across it sooner or later.
    BTW, thanks for the spread sheet.
    BJK
    Jan 2007
    Arizona
    187
    I don't know for sure if this is the data I need.
    BJK
    Advanced Tuner HartRod's Avatar
    Dec 2006
    Pensacola, FL
    483
    Quote Originally Posted by 07MontRedcp View Post
    BJK
    Thats it. DSTECK thanks for posting the info. What improvments have you seen with this setup as compared to the Bannish data? Idle? Top end? Fuel economy? (I had to throw that one in, ).
    69 Suburban Bagged & Blown: http://67-72chevytrucks.com/vboard/s...d.php?t=200387
    68 Farm Truck build thread-LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
    Jun 2007
    Finland, Europe
    549
    Thanks Dave again.
    Dec 2006
    Pensacola, FL
    483
    Dave for the SD80's, would I still use 4.0 ms for the Short Pulse limit and 1.1 for the Min Injector pulse to go along with your spreadsheet? Thanks,
    Rob
    Mar 2008
    St. Louis, MO
    4,859
    You can make it low. Those injectors suck.
    Dec 2006
    Pensacola, FL
    483
    LOL, I get it you don't like them, but I'm stuck with them for right now. Can you be more specific? Make which one low and how low? Here's the log and tune of where I am right now. I was just trying to fine tune the IFR with your data.
    Mar 2008
    St. Louis, MO
    4,859
    You shouldn't be changing fuel flow rates to change your tune.
    Dec 2006
    Pensacola, FL
    483
    Damn Dave, all I asked was a simple question. I'm still finishing my tune and wanted to update my fuel injector data with your numbers. I feel your numbers are well thought out and will probably help my truck run better as I continue to fine tune my setup. I realize you probably get asked a lot of "stupid" or repeat questions, but if you aren't going to add any more to it that, why bother posting? I'm a member of about 5 different boards and probably answer 10 or more questions a day (most repeats), but I try to answer them all "graciously" because I know how hard it is to find information when you have a limited amount of time. Geesh, it's people like you that run people off of boards.....I know, I know you are widely respected on this board, but it's only because of your knowledge, NOT your bedside manner. Sad part is, you could add so much more to this board if you didn't feel like you have to act like a pr^&* all of the time...OK, I'm done ranting and I'll stay out of your threads and won't "bother" you any more.
    EDIT: Read this, maybe you will learn something...http://www.hptuners.com/forum/showth...8-from-scratch
    Mar 2008
    St. Louis, MO
    4,859
    Actually, I read your post as though you were trying to adjust fuel delivery by editing IFR instead of calibrating the MAF. That's why I posted what I did.
    Don't like my posts? Don't read them. I will still sleep at night. Maybe I just shouldn't share the tools I create. I've handed out free tunes and done my share (and other people's share) of help. One guy tried to pay me, and I had him donate to the Make A Wish foundation instead. I didn't post my reply with intent to be rude. It's also not my problem if you're stuck with those injector. And you're right, I do constantly get asked questions to the point that I asked HPT to increase my PM limit, and I still have to clear it weekly. Many of those questions have already been answered on this forum and are born out of a person's lack of initiative to do a search or find it on their own.
    The minimum pulse width is the lowest "controllable" limit. You can set it to whatever you want. If you don't set it low enough, you'll never lean out. Things like this have been answered on this forum before.
    http://www.hptuners.com/forum/showth...l=1#post333562
