Can some one please look at this tune and log to verify that it is from a stock GM stage 2 file?
I pulled the tune from the PCM after I flashed it back to stock from Trifecta, but my confidence in Trifecta is low. I just want to be sure that the tune that sent me as the stock GM stage 2 tune is correct. The reason the tune file says modified is because I went and disable the VAT since the VINs currently do not match. I did do a case relearn and it took.
Thank you.
