Results 1 to 14 of 14
Thread: Why is there a MAF table in a 3 bar custom OS?
    I'm looking at a tune from a gen 3 with a 3 bar SD OS and noticed that it still has a MAF table. Why? Does the MAF table do anything?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,856
    You can still use the MAF.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    195
    Dave do tell thought any of the 1/2/3 bars OSs just ignored the MAF freq table?
    Western New York's Performance Headquarters
    716.830.0506
    Aug 2009
    Calibrating
    3,371
    Some ignore it and some don't. Only way to really know is try
    Aug 2005
    Western New York
    195
    Quote Originally Posted by Ben Charles View Post
    Well I know the Fbody OS it doesn't work. Any Gen III stuff that it does work with?
    716.830.0506
    Mar 2008
    St. Louis, MO
    4,856
    I've used the MAF on a 3 bar OS in a 2004 GTO.
    Aug 2009
    Calibrating
    3,371
    Ive used the MAF on my 2bar OS from my 02 WS6 411 computer
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Dec 2008
    on the Dyno
    1,825
    Seems like some of the earlier OS's ignored it no matter what. My 2000 Camaro was one of them. I've never had a car to use both on a gen3 though cause most go SD to get away from the frequency limitations of the Gen3 PCM's.
    Located in Central Kentucky
    ShorTuning
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,247
    From what our head engineer has said in the past the maf was basically taken out of the picture in the earlier LS1 operating systems that have the secondary VE table in stock form, so you might be able to use the maf in some of the newer operating systems the older ones the functionality needed to be removed.
    Dec 2008
    on the Dyno
    1,825
    Good info Bill and backs up what I have seen/experimented with in the field.
    ShorTuning
    Is this also the case with some of the earlier Vortec truck engines like say a 2000 5.3L?
    Dec 2008
    on the Dyno
    1,825
    I would assume so as the earlier vortec's shared the same OSID as most of the F Cars.
    ShorTuning
    Advanced Tuner VodeAn's Avatar
    Jun 2012
    230
    I don't want to get into a MAF vs. SD debate, but what makes you want to use the MAF with the custom SD OS?
    I usually get everything I need out of the SD. Pretty little variance in AFR even in ambient temperature changes.
    Dec 2008
    on the Dyno
    1,825
    Double the resolution if you can keep the MAF. Cover your right eye up with an eye patch and you can still drive to the grocery store but you can see much better with both eyes correct? Similar with the PCM, if you have more data/sources to predict/calculate airflow it will be more accurate and seamless. I'm not saying SD is bad I'm just saying when properly done it'll never be as good as a blended setup. The blended setup has everything a full SD tune has (because it still utilizes it) and everything a MAF tune has.
    ShorTuning
