Results 1 to 8 of 8
Thread: Why no STFT or LTFT data in charts when logging?
    I have a cammed LS1 swapped into an RX7. I got this tune as a mail order base tune and am proceeding now to dial it in. It is an SD tune and from what I can tell is not being forced into open loop, but I am not getting any fuel trim data in my charts, all fuel trims are stuck at zero, so are the histograms, and 02 voltage is flat at ~443mV. Does this indicate I have an 02 sensor problem that might be causing this? Am I missing something in the tune?
    I get all the fuel trim info and varying 02 voltage when I plug into my 09 CTS-V.
    The VE is still a work in progress, I was screwing around with logging here.
    I have attached my tune, config and a log. I hope I attached them correctly.
    Thanks for any help or tips you can provide!
    rx7_log_2.hpl
    rx7_corrected_inj_flow_base_pe_modded overall ve.hpt
    Default Wideband.cfg
    If your O2 voltage is flatlining at or around 44x mV, that strongly suggests an open circuit on the O2s which will cause a Gen 3 to remain in Open Loop.
    Advanced Tuner Pro Street's Avatar
    Aug 2006
    806
    244
    Did you figure this out?
    I have a 5.3 swap into a 1995 Pickup. Had the harness custom built and same guy sent me the 0411 pcm and he had flashed a 2002 5.3 pickup tune into it. Runs and drives fine but will not go into closed loop and O2's are stuck at .447 STFT and LTFT are 0%
    Any help?
    2018 GMC Denali A8 6.2L
    2016 CTS-V
    2016 C7 Z06 A8
    2016 C7 Z06/Z07 A8 vert
    2015 Chevy SS 6.2 LS3 A6
    1996 Impala SS LT1 CAI
    1995 Chevy 1500 5.3 CAI Z06 cam
    1957 Chevy vert
    Aug 2006
    806
    244
    Forgot to post my tune!
    3.73 to 3.42.hpt
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by Pro Street View Post
    3.73 to 3.42.hpt
    Do you have any logs to post? Any DCT codes? Re-enable P0135 and 0155 (SES checked and MIL on Second Error), Any codes now? Check wiring from PCM to O2's. Tune shows CL enabled so O2's s/b toggling or at least moving a bit as well.
    Ed M
    [email protected]
    Aug 2006
    806
    244
    Thanks for the info! I will enable P0135 and P0155 and give that a shot. Also I will get a log when I get the intake manifold back on later today.
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
    Aug 2006
    806
    244
    Here is a log and tune!
    2nd log.hpl
    3.73 to 3.42.hpt
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
    Aug 2006
    806
    244
    2nd log.hpl
    3.73 to 3.42.hpt
    Fixed it! Called the guy that made my harness and supplied my pcm. He said I had the wrong O2's. Told me the one's to get and it is working great now!!!
    2016 CTS-V
    2016 C7 Z06 A8
    1957 Chevy vert
