I have a cammed LS1 swapped into an RX7. I got this tune as a mail order base tune and am proceeding now to dial it in. It is an SD tune and from what I can tell is not being forced into open loop, but I am not getting any fuel trim data in my charts, all fuel trims are stuck at zero, so are the histograms, and 02 voltage is flat at ~443mV. Does this indicate I have an 02 sensor problem that might be causing this? Am I missing something in the tune?
I get all the fuel trim info and varying 02 voltage when I plug into my 09 CTS-V.
The VE is still a work in progress, I was screwing around with logging here.
I have attached my tune, config and a log. I hope I attached them correctly.
Thanks for any help or tips you can provide!
rx7_log_2.hpl
rx7_corrected_inj_flow_base_pe_modded overall ve.hpt
Default Wideband.cfg
