This truck was dumped on me and it's kind of a mess that i'm trying to sort through. I'm wondering if the MAP sensor linear and offset are correct. They're at 305kpa and 10.33kpa respectively. I'm seeing 30.13 inHg on the Barometer here, or 102kpa, and my MAP is showing 105kpa KOEO. I took the truck out for a quick log and the MAP never recorded over 105kpa at WOT, so something isn't right. The tune that was in the truck when i got it is attached below. I've never actually messed with a custom OS before. The MAP sensor is a 12223861.
I'm curious if the injector data is correct as well. It has Ford green tops in it. The trucks mods are unknown. It supposedly is bored over a little with "good pistons". Supposedly has a mild cam, but it almost sounds stock at idle. It has a Whipple supercharger with green top injectors and headers is all i can say for certain. The truck was flashed with a 3-Bar SD OS. The owner took it on trade and wants it to run better. The tune was supposedly done twice by "some big shop in Kansas City," I was told.
