What in gods name in this tune would cause this issue. Mafless - I attached my stock tune because the VE is already tuned on my copy..... all stock settings that are in file file minus the usual maf disable gear.
1. Startup and it chokes for a second then idles........ sometimes when it's hot, it wont even start.
I did some reading outside these forums due to 'not getting any help' as such...... some people have drilled a little hole in the TB and adjusted some stuff.
My wideband shows it runs 18AFR for the initial second or two, then richens and smooths out..... but it chokes, and timing is in the negative......
Is this some sort of idle overcorrection?........... I want an actual tuner who's done a mafless to respond please, I dont need idea's untested or opinions..... I need someone who's encountered this issue. I have tried all the various idle airflow tables etc.......
I have now tried setting the startup idle flare to a max of -10..... which I will try tomorrow....... I heard increasing the cranking spark can help....... any other idea's? ........ I have also started the car, put it in drive and went to drive off and it conked out...... it seems like some sort of timing issue.
