Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Target lambda for e85 tuning fg xr6 turbo
    Jun 2013
    15
    I know this is quite a different fuel to 98 octane petrol. I have gathered stoich is around 9.7 or 0.9 lambda .. at wot I am thinking around .80 lambda. What are the target lambdas on light medium throttle? Am I on the right track for wot and idle stoich? If this were normal fuel I would be sweet..any input appreciated
    Sep 2011
    Jax, Fl
    213
    Stoich is 1.00 lambda no matter the fuel.
    2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
    L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
    JHP V2 I Powdercoated Black 18s I Kyne Splitter
    2001 GTP I Stock DD
    Oct 2011
    QLD, Australia
    267
    Kyne is correct.
    I currently use 9.87 for Stoich with E85, Running on the united pump E85. Theoretically your target lambda in the base fuel table doesnt need to change.
    I was running .79-.78 uptop on pump 98 but Ive heard if guys lifting cylinder heads at that lambda or richer with big boost ie25psi and above. Im currently running in the zf I've just built but when i decide to retune I will will try a few different target lambda values to see what achieves the best result,with about 23psi
    Jun 2013
    15
    The lambda is always the same for different fuels as I understand it. I don't want to go to 25psi as it is a daily driver . I will try 9.87 stoic and yes I found e85 from united quite good. I targeted a leaner 0.82 lambda on wot on pump fuel the car goes good. Hmm I wonder if I can also go leaner on light load light throttle to get better fuel economy as an experiment ON E 85. This will be interesting and most of all funIt is currently getting 24 l/100 consumption untuned at the moment so see if I can flesh out idle leaner part light throttle because while I am impressed amazingly with the extra punch of this magic fuel it can be an inconvenience refueling more often. See how I go and may share a few tips to help others because I see most people are reluctant to share a few ideas. That is ok I will
    Thanks for the input so far guys.
    Feb 2006
    Canada
    1,700
    This would be a guide only, but will get you close, really close actually. Lambda, E85, Gas
    0.730 7.125 10.731 @ Max Power Multi Turbo
    0.740 7.222 10.878
    0.750 7.320 11.025 @ Supercharged/Turbo
    0.760 7.418 11.172
    0.770 7.515 11.319 @ Max Power NA
    0.780 7.613 11.466
    0.790 7.710 11.613
    0.800 7.808 11.760 @ Consistant Race
    0.810 7.906 11.907
    0.820 8.003 12.054
    0.830 8.101 12.201
    0.840 8.198 12.348 @ Part throttle RACE
    0.850 8.296 12.495
    0.860 8.394 12.642
    0.870 8.491 12.789 @ Idle
    0.880 8.589 12.936
    0.890 8.686 13.083
    0.900 8.784 13.230
    0.910 8.882 13.377 @ Part throttle STREET (economy)
    9.76 would be lambda
    2000 Trans Am WS6
    Sep 2011
    Jax, Fl
    213
    .77 for Max power NA? I would check your numbers.
    2001 GTP I Stock DD
    Feb 2006
    Canada
    1,700
    Just a guide guys, meant to be a starting point. Get it on a dyno asap after and find what the engine wants to dial it in. Although, I think you will find the boosted #'s to shoot for are quite accurate in that chart
    2000 Trans Am WS6
    Sep 2011
    Jax, Fl
    213
    Why would you want idle anything but Stoich? In my experience it should be this
    Idle/part throttle/cruising - 1.00
    Max power NA. ~.88
    Max power supercharger. ~.78
    Max power turbo .72-.75
    I think your multi turbo is correct but I think the others are off by quite a bit. Turbo is a bit harder to say an exact one, and the rest are approximations but I would say those are good starting points and where I start to tune from. The last LS9 I did I leaned out to .79 at max power.
    2001 GTP I Stock DD
    Feb 2006
    Canada
    1,700
    Couple days ago, LS1, 12lbs, Meth, E85... best power was at .74 leaned out to .76 up top. So it's a pretty good ballpark I thought as well. The chart is originally from the engineers at Honda, and they too advise it is for a starting point only
    2000 Trans Am WS6
    Jun 2013
    15
    Thanks for the input guys. Over time it is what each setup wants. Different cars setups will perform best on their sweet spot Tuning from a safer starting point then slowly making changes is the way. I have avoided dynos but actually use the 1/4 mile track so far to measure results and log. Yes I know I am taking the long way but it works for me while having the enjoyment to run it at same time
    To figure what lambda You need, EGT is a must, this with dyno puls (or better road or 1/4 mile) WOT while logging timing (knock) and EGT will tell You. For me it's a must in modified engine. You don't need that when You do second identical setup, but any new - buy EGT, cheap insurence.
    Without that, You never know where You are.
    Some example, lower timing (lot of people do that in non build engines while boosting them) makes EGT much higher than when it could be when timing set for max power, then You must make it more rich to compensate. When You do correct timing, You can go leaner, in this case making more power and have safe EGT.
    When engine is forged, You can do nearly what You want, Your best lambda will be lambda vs timing making best power with EGT You want.
    I've seen some custom tunes delivered with SC or turbo kits with not really much boost (5-8psi) that were at 0.82 and EGT was 300F more that N/A.
    Making it 0.79 bringed EGT to n/a level (safe timing).
    Another mustang with turbo, safe timing, 10 psi. lambda 0.79, close to stock EGT, same car with build engine, timing set to max power and final lambda at 0.83 (so leaner) and EGT close to stock.
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
    I was under the impression .82-.85 Lambda was optimal for NA applications to be safe but still make power.
    Theres been a huge problem with the new Coyote motor in the 11-13 Mustang GT's tossing #8 cylinders due to improper fueling. They like 11.9AFR up top to be safe.
    Stav and Canigga make a very valid point - one that can be applied to saying there is no blanket Lambda and every application is different.
    Total Masshole.
    2013 Mustang GT Premium - Stock Until HPT Releases Support!
    2009 Cobalt SS/TC Black Sedan
    227whp/224wtq Stock. Dejon CP, K&N SRI, Forge BPV, Catless, BadMab Catless DP, MPx 3" Catback, HPT Tuned 328whp/425wtq. SOLD
    2004 GTO Pulse Red 1 of 512 - R.I.P. 5/31/09
    Oct 2007
    Eastpoint, FL
    850
    Quote Originally Posted by Gremlin85 View Post
    Speaking of the #8 cylinder problem. I do not believe the problem is fueling related. Rather, it is from improper tuning, IE using global spark adder.
    Ah, gotcha! Thanks Eric!
    I was just going by what some SCT tuners have mentioned. I am anxious to open up my 2013 GT and see whats what as far as tables and tuning abilities go. I have never touched SCT so these are completely new for me
    Total Masshole.
    Sep 2011
    Jax, Fl
    213
    I would think it's like the LS engines, the back cylinders run lean or are too hot so they need more fuel to compensate for that cylinder.
    And I agree there isn't a blanket lambda setting for max power, depends on the engine design. Apparently the DI engines like leaner mixtures according to that other vette thread, but the settings I posted are what I start with and usually I don't even change them.
    2001 GTP I Stock DD
    Oct 2011
    QLD, Australia
    267
    Quote Originally Posted by Kyne View Post
    Kyne and Eric a question. In those instances where you know you have a certain cylinder leaner/hotter than the rest, without the ability to control injectors individually or spark for that matter, only globally. I can't really think of a solution.
    I Dont believe calibration of the knock sensitivity in relation to cylinders is the answer. Would it not be better to have consistance spark for each cylinder and be able to injectors individually? I dont believe we have that ability with the australian fords as logging the EGT's for each cylinder is on my to do list.
    Knock adjust is not all, you can have knock ok, but cylinder melted, maybe in coyote is this problem, I don't know.
    I'll add some info for per cylinder tuning as I was in situation I needed quick solution to fix the problem.
    If in the car is one egt, simplest solution will be compare temperatures of single cylinders.
    It can be done directly at exhaust just after wot run, switch off engine as fast as possible, what in long term is not good and not pretty acurate anyway (but easiest), and use laser meter. I used laser meter with USB hanged inside engine compartment and directed to cylinder I want, but with USB connection and constant metering option, to see on the fly and that's very acurate. Then I was able to adjust mixture of worst cylinder at first to match temp of rest, of course if there is available correction of single cylinder. I did this so with aftermarket ecu's (VEMS) that had such correction in one rally build having problem with overheat one cylinder due bad intake design (problem after engine was boosted).
    Second option is old school method is watching every spark plug after such run.
    And third option without measuring temp for every cyl is leaning mixture or advancing timing till you see knock activity and then riching cylinder having problem (if You have knock that shows every cyl). All till all cylinders will react similar for leaning or increasing timing. But you have to be sure engine will handle those experiments in short time...
    Fourth, dyno tune for best power at every cylinder, changing only mixture (after it, You can do same with spark if such option available).
    When You get into detonation, CHT will grow up and EGT will fall down, EGT should grow with rpms. Since knock sensor are acurate, this is marginal problem ( I was reading about, but i've never experienced this).
    There is some topic on another forum (can't find it now), where man states that he's tuning single cylinder in Mustang via SCT and gaining more power from that. I have no SCT, so can't tell if there really such option is.
    So if there's not such solution, as per cyl correction, then there must be rich mixture to satisfy one cylinder, then all 7 cylinders are under powered (or use piggy back with that option, just to fix this).
    And one more about EGT, it's good to have base for compare, eg before mods.
    Having egt for all cylinders is of course best option...
    www.hd-customs.pl
    Oct 2011
    QLD, Australia
    267
    Hiddeous, chime in now, and let the boys know what that table is in SCT
    Jun 2013
    15
    Well after all that I realised my injectors are not up to the job with e85 so went 98 premium fuel coupled with the fact that the fuel economy had me looking for a fuel station to fill up every 230 killometers the 98 fuel gets me almost double the distance. Still went to the track last week tinkered a little more and pulled 12.3 1/4 . Just got one run with the fresh tune so might go one day again see how she goes
    Oct 2011
    QLD, Australia
    267
    that is a nice effort..what sort of MPH?
    Before I went to E85 i was on pump 98 with the stock turbo making roughly 490rwhp running 11.6@120mph on street tyres. Having a heap of issues with the ZF as it wouldnt shift 3-4th at WOT.
    After that went to E85 and a rough tune as was running out of pump and went 603rwhp @ 19psi with a GTX3582r but haven't race it yet at Ive just rebuilt the box and im trying to fix that no shift issue.
    230km's is pretty low. I know E85 economy is poor but even on my 600hp tune I get atleast 320ks to a tank around town. I haven't run it on the highway yet.
    Check the 02 sensor signals, you might have a crook one.
