I am trying to tune my VE Table in open loop, MAF de-activated, via Greg's (Calibrated Success) approach:
Actual Wideband Lambda/Commanded Lambda = Lambda Error (VE multiplier)
However I simply am using:
Actual Wideband AFR/Commanded AFR = AFR Error (VE Multiplier)
He says to use the "Commanded AFR Hi Res" parameter. When I insert this as a PID, it is there until I start scanning and then it says parameter not supported. Why is this?
Also my PLX wideband works fine with the gauge it came with. As soon as I wire it into the EIO1 of my HPTuners Pro, it does not readout on the gauge and the value reported back in HPTuners stays constant at ~10.6AFR ALL the time. It is not updating or changing. Any ideas? Thank you!!!
