CTS-V 09 can not be start normally without little gas pedal, mostly in normal temp but in cold stat is perfect, I tried to increase the startup airflow and tweak the cranking timing but no improvement.
so how can I reach to perfect startup in warm temp
what I did is reduce the number in fuel cranking table @ higher temp and increase the timing also @ higher temp
but I dont know if what I did is right or not because I keep subtract and adding by 120%
I have attach for two warm start log
