What is an acceptable difference between banks one and two for fuel trims? Bank 1 is at +1.6% and bank 2 is sitting at 0. Which makes for a good overall trim in the histo, but thats an aveage, shoudlnt the banks be closer to each other?
Chris
Chris
2009 Silverado Crew Cab 5.3L, stock.
mine are off a bit more than thatmy bank one is normally about 3-5% leaner
Sulski Performance Tuning
wow! so is that not a bad thing for dialing the in the fuel? I'm not so worried about mine anymore! I thought I had an exhaust leak that turned out to be my exhaust hanger rattleing, so I ruled that out.
Chris
exhaust leak, mismatched injectors, so many variables. i think mine are just in the o2s maybe. thats why i am going open loop and tuning with a WB. and i will be using bank one which will be slightly leaner anyway and then ill be safe any way i do it. my injectors are also flow matched
So you think I will be ok when I start tuning in Open Loop with my wideband?
Chris
yeah dont even worry about what the narrowbands say, the wb will tell you what is really gonig on
