My C5 runs great at WOT with a 233/239 cam and 90mm TB, NA. Overall the tune is good, VE and timing tables are tuned. The only problem is throttle response. If you are cruising at 3000 rpm, and give it a small throttle input, there is a dead spot, or throttle lag. Downshifting for road racing is a problem with this throttle lag. I recently made a small change to the injector timing, that helped.
Now I am looking at Desired Throttle Area.
I see the warning about permanent damage. How much change is safe. Will this short out the PCM if I change too much?
