Results 1 to 8 of 8
Thread: Can 2000 OS be flashed onto a 99 pcm to get a 3 bar upgrade?
    Aug 2005
    335
    Just wondering if a 2000 OS be flashed into a 99 pcm to get the 3 bar option?
    TIA!
    GO RAIDERS!!!!!!!!!!
    02 C5 Z06
    8.8@160
    Sep 2008
    1,668
    Do you mean an LS1 PCM? If so, yes, and to be honest, I'd go with a 2002 OS...12212156 is I believe the newest OS you can put into a 99-2002 LS1 PCM.
    2023 Durango Hellcat
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    195
    Yes but like MikeOD said I would move right up to the 2002 OS for the '411 PCM. The only thing you will not be able to keep is the stock vehicle VIN everything else will work fine
    Western New York's Performance Headquarters
    716.830.0506
    Aug 2005
    335
    It's weird I tried it last night and it did not work. I noticed the security light stayed on on the dash. Car would fire for a second then shut off. Loaded the 2 bar back in and it fired right up.
    02 C5 Z06
    8.8@160
    Aug 2005
    Western New York
    195
    Quote Originally Posted by vortech View Post
    Write Entire & relink VATS?
    716.830.0506
    Sep 2008
    1,668
    Post what you flashed in. If you don't have the MAF fail stuff set correctly, it'll start/stall instantly like that.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Do you just want a 3-bar capable 99 operating system? Is this for a F-body?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Tuner Chevy406's Avatar
    Nov 2007
    Huntsville, AL
    163
    Not all '99 ECMs are created equally. My early '99 Corvette's ECM is not the same as the later '99 ECM that I use in my Nova and they have different enhanced OS choices. You may not be able to run 3-bar OS if you have one of the early ECMs.
