Results 1 to 4 of 4
Thread: having touble disabling vats on 2003 impala
    Oct 2013
    5
    yes I have set vats to PWM also checked all4 of its p codes for vats
    but nothing works car starts for 2 seconds and kills fuel pump is running but inj pulse is killed MIL light flashes for security can some please help me
    same car has charged me 4 credits for same car
    Dec 2009
    1,084
    Might want to post your tune.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    also log the vats status bit in the scanner, this will tell you if its a vats issue or not.
    Feb 2006
    Canada
    1,957
    Adjusting for vats will do nothing for you if the cylinder has gone bad. Swap the ignition cyl with a "known good one" and I bet your troubles vanish in the night. I had this issue with my Grand Am and this was what finally fixed it.
    I work at a GM dealership, and one of the mechanics had a cylinder in his tool box that he gave me, swapped it over and two years later still working perfectly. And yes, vats was properly disabled the entire time
    2000 Trans Am WS6
