Results 1 to 18 of 18
Thread: 2009 Fseries Tuning support released
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    Its been a long time coming but we've finally released ECM tuning support for the 2009 Fseries V8 trucks.
    With access to over 420 tables you'll have plenty of goodies to edit to get the best tune possible out of your truck
    Rest assured we are also working on the 2010+ Fseries & Mustangs but wanted to get our feet wet with this initial release for this new generation of pcm.
    -HP Tuners team
    Feb 2006
    South Carolina
    1,525
    Nice to see Bill. These new PCM's ought to reinvigorate the HP Tuners Ford tuning crowd and move some credits.
    Jaime
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    I see that the 2009 F150 has wideband O2's!
    Russ Kemp
    Jan 2011
    VENEZUELA
    126
    yes and a bunch of tables in the new fords are 4d stuff
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Correct, the 2009+ F150 runs closed loop at WOT. You set desired commanded lambda and adjust the tune to get the fuel trims in line. It is a very forgiving system, because your tune can be way off, but the fueling be perfect (PCM making huge corrections). The 2011+ Mustang uses a similar system, although much more complex due to the TiVCT controls.
    Dec 2005
    Regina, Sask.
    4,214
    Is the 6R80 trans fully supported? Any tips on firming up the shifts? Can you post a stock 2009 F150 tune?
    Russ Kemp
    Oct 2007
    Crawfordville, FL
    2,412
    We do not have TCM support yet Russ.
    Here is a stock file.
    Dec 2005
    Regina, Sask.
    4,214
    Any ETA on the TCM support?
    Russ Kemp
    HP Tuners Support
    (foff667)
    28,266
    I don't believe so, I'm pretty sure we'll see 2010+ fseries & mustang ecm support before we see tcm support for these to be honest.
    Dec 2009
    1,084
    Wondering how you are making out with the 2010 F series? since the one I have access to seems to have the same (at least in name) OS as an 09.
    Is it just adding the 2010 Vin info or is there much more than that?
    Thanx. Doin an awesome job!
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by planethax View Post
    What is the OS? I think some of the OS IDs are the same for 09-10. The VIN info does need to be added as well. The 2010 F150 will be out soon.
    Dec 2009
    1,084
    rxge6c2
    Oct 2007
    Crawfordville, FL
    2,412
    I'm pretty sure this is a 2010 only OS. I have to finish the definition for it.
    Advanced Tuner Japeatr's Avatar
    May 2010
    Dallas Texas
    321
    any ecoboost support?
    384whp/303wtq
    Built 2.0LSJ: TVS w/2.6, 1000cc, Stage 2 cams, custom fuel system, E85, Dual Pass, 3"intake, 3" Catless exhaust, CIA midlength Header
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by Japeatr View Post
    Not currently. It shouldn't be too far off though.
    Dec 2009
    1,084
    Eric, is there read support for this yet?
    The truck will be coming by in the next few days and will grab file off of it if I can.
    rxge6c2
    HP Tuners Support
    (foff667)
    28,266
    it should read it fine, however the definition is still not done yet.
    Oct 2007
    Crawfordville, FL
    2,412
    I already have that file read, it is just in queue to have the definition done.
