Results 1 to 7 of 7
Thread: 2010 Camaro P0106
    Dec 2012
    North Carolina
    119
    2010 Camaro P0106
    I have a boosted 2010 Camaro with the red label MAP sensor. Now that I've been turning up the boost above 10 PSI, it often trips a P0106 (MAP/Baro Sensor Range/Performance) error on fast acceleration. I have the linear & offset at 312.50 & -11.25. And the MAP Delta pegged across the board at 255.99 ("256") under Engine Diag -> General -> P0068 -> MAP Delta
    The red label ZR-1 MAP sensor is a 3-bar, right?
    Any suggestions on what to change?
    Nov 2009
    All Around
    3,149
    I believe the E38 PCM max support MAP sensor is 2.5 and ZR1 is 3 bar
    Dec 2012
    North Carolina
    119
    Thanks for the info! IDK that, but will go buy a 2.5 one.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Disable the test. That code isn't meaningful.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Dec 2012
    North Carolina
    119
    Will do. Thanks!
    Sep 2008
    1,668
    You can use that MAP sensor, just disable the code/test.
    2023 Durango Hellcat
    Dec 2012
    North Carolina
    119
    I disabled it this morning. Thanks for the info guys
