Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 72
Thread: Transient Fuel: Tips, Tricks, and Info. A how-to guide
  1. #41
    Quote Originally Posted by Stuffs View Post
    thanks for sharing James
    For sure! Awesome!
    My car is bagged & stored for the winter, near ready for a retune as I swapped the cam this fall. A multitude of self enflected problems has left me in a spot if I should pull the heads in the spring or just put new rocker arms on & continue tuning.....rambling on my part....
    I've watched this thread & have wondered how this applies, when I'm MAF only I have a very lean condition on deccel as I have slight lean condition on very light throttle acceleration. In SD only the lean condition on deccel is tuned out, the lean condition on very light acceleration is nearly non existent. I've never run a blended tune, I need to. I do prefer the MAF only tune as I feel the car runs better overall. If I were to correct the MAF only conditions with the Transient Fuel tables that would change how the VE table tuned...correct? The Transient Fuel would tune differently in all three conditions.
  2. #42
    Advanced Tuner JamesLinder's Avatar
    Jan 2011
    Bella Vista, AR
    363
    Tuning transient fueling
    I spent about 8 hours tuning transient fueling this weekend and have managed to get it very close.
    I had to decrease impact factor for 20 (quite a bit), 40, 80 and 100 MAP (too rich) and I ended up having
    to increase 60 MAP. I had to increase boiling rate for 20 (quite a bit), 40, 80 and 100 MAP (too rich) and
    decrease it for 60 MAP (to lean).
    I ended up with Gains for both tables at stock values. It takes a lot of time tuning transients but it is well worth it
    because once the transient fueling is correct throttle response is super crisp and the PE vs RPM AFR immediately
    hits 12.7 to 1.0 when going WOT and stays there throughout the entire RPM band.
    No one has ever stressed how having this tuned properly makes a HUGE difference! Attached is latest tune and
    stock tune so you may compare.
    Last edited by JamesLinder; 01-07-2015 at 07:32 AM. Reason: REVISED for FINE TUNING
  3. #43
    Jan 2011
    Bella Vista, AR
    363
    Please note that my write up above was revised for accuracy
    After additional tuning, I had to revise my write up for accuracy. Please re-read. Thank you.
    If we work together we can do this!
  4. #44
    Jan 2011
    Bella Vista, AR
    363
    Ctd
    You would be better off to use both MAF and VEs. Yes, transient fueling errors make VE tuning much more difficult
    because this makes it much harder to obtain steady state readings for the areas of the curve where magnitude of
    these errors are the highest.
    If you tune on the street it also can make MAF tuning more difficult since it is not easy to hold everything steady state
    when driving on the street while tuning ANY parameters, however it is obviously more difficult for the 3-dimensional
    VE table than the 2-dimensional MAF table.
    Now that I have gotten transient fueling much closer to ideal, I was able to re-tune the higher flow rate region of
    the MAF curve with a great deal more accuracy. With the transients gone it was much easier to see what was really
    going on (quantify the AFR errors) at the higher flow rates.
    Once you have a perfectly dialed in MAF, it will help get the VEs in line because they are "corrected" on the fly as you
    drive by using stead-state MAF values. The PCM has a table of VE correction factors that it updates for several
    combinations or "ZONES" of MAP and RPM. Although these correction factors are in the PCM, it appears we can only
    see the "starting point" correction factors for each zone, not what they are corrected to over time (which would be very
    useful if we had this information). I assume this is how the self-tuning EFI systems work (Holley) because they have a
    great deal of freedom to "tune" while you drive.
    Oh, if you have headers, I strongly recommend leaving your PCM in open loop mode after tuning. Closed loop fuel
    trims simply do not work correctly with headers. Optimal performance will occur once you dial your motor in using
    a wide band and going back to closed loop will result in the fuel trims making corrections at the wrong time. Once
    you dial everything in using the wide band, and if you have MAF, VE and transients calibrated correctly, then fuel
    trims can only serve to degrade performance. I do recommend using a wide band continuously with the alarm feature
    enabled for lean conditions (check out Zeitronix and DashDAQ products) so that you will be aware if a fuel injector
    starts failing or anything else should cause your motor to suddenly go lean.
    Just fyi, I even tried using just short-term fuel trims in open loop, and even these were not correcting fueling correctly
    because they simply do not respond at the proper time because of their location in the exhaust being further from the
    exhaust valve than GM's stock exhaust location. I also found that installing the wide band oxygen sensor, which I
    leave installed and operational at all times, works best if installed in the bung at the header collectors instead of
    further back at the second bung when there is one. I highly recommend the Zeitronix wide band controller for its
    accuracy, reliability, and alarm programing features. I'm using this unit to trigger a lean cut-off relay to turn my N2O
    system off if AFR should become higher than 12.0 WHEN nitrous is flowing, and I log the LCN-2000 timing retard
    signal during nitrous runs with this same controller to confirm its doing its job to protect the motor. I also highly
    recommend the DashDAQ unit which is easily connected to the Zietronix controller to continuously monitor about 12
    key operating parameters in real time continuously. When not logging you can still see what is going on at all times
    at a glance; it looks identical to a GPS unit mounted on your windshield, however it connects to the OBDII port and
    can monitor (and log to memory card) just about every operating parameter (although not all of those available
    using HP Tuners' logging software).
  5. #45
    Jan 2011
    Bella Vista, AR
    363
    Picture of DashDAQ Display
    Here is how mine is typically configured, but there are 8 or more screens you can scroll through like this or
    they can be set up as graphs of RPM and other parameters just like a logger will display and there are other
    features that you can use to monitor a ton of things. You can configure it to compute TQ and HP and log
    these with other parameters its obtaining from the OBDII port and the AFR wide band.
    It is nothing less than remarkable!
  6. #46
    Jan 2011
    Bella Vista, AR
    363
    Update on Latest Transient Tuning Efforts
    Wow, dialing in these tables requires a lot of trial and error. It is a moving target because every change you make
    for a specific MAP column affects the behavior of transient fueling in the other MAP columns - because as a previous
    tuner mentioned the values entered affect fueling because of their values "relative" to one another.
    In order to get the lower MAP fueling values to fall in line I had to change ALL OF THE higher MAP values above them
    in both tables. Through trial and error here is the final tune I ended up with. As you will see the changes from
    stock values are now much different than before. This is the closest I will probably be able to get to keeping AFR
    constant and at stoichiometric during all the full range of throttle tip-in and tip-out at various MAP values.
    If not for my DashDAQ I'm not sure I could have accomplished this because logging does not work as well for me
    as watching the changes real time on the DashDAQ readout. It takes a lot of trial and error! I would be interested
    in knowing if my changes from stock should provide an improvement for most motors that have been upgraded
    with cam, heads, intake, headers, MAF, etc to flow as much air as possible. Anyone trying my transient fueling
    tables in their tune, please let me know.
  7. #47
    Jan 2011
    Bella Vista, AR
    363
    REVISED - Summary of Changes from Stock OEM Settings
    please see attachment - this is for latest tune I posted above.
    Custom Built, Forged 408 CID LQ9 - TX Speed & Performance
    (thank you Gary Luther)
    WiseCo 4.030 -8cc Pistons, Lunati Rods, 24x Lunati Crank
    199-AsCast, Precision Race Components cathedral cylinder heads 68cc; 10.7:1
    TSP Custom Order Comp Cams: 227/235 .614/.621 on 112LSA
    GM LS7 hydraulic lifters; 1.7 ratio GM shaft rocker arms with trunion upgrade
    PTM 102mm Throttle Body; Fast Toys 104mm Air Cleaner Lid with ram air hood
    FAST 102mm Cathedral-Port Intake Manifold (146302)
    TSP 100mm MAF, 2006+ Corvette Z06 GM MAF Sensor (recalibrated IAT)
    Bosch 41.7 lb/hr at 4 bar fuel injectors #0280155811
    Kooks Long-Tube headers with Y-pipe; CATs removed
    GZ Motorsports LSX Series Sportsman Crankcase Vacuum Pump Kit
    Meziere 680-WP319S Electric Water Pump
    Racetronix Fuel Pump Kit (255L/Hr integral Walbro pump)
    2000 Camaro OEM PCM (GM service code 09354896)
    Last edited by JamesLinder; 01-16-2015 at 02:35 PM. Reason: REVISED FOR CHANGE TO 100 MAP Impact Factors
  8. #48
    Oct 2004
    Orlando FL
    766
    I was not clear that the changes you were making could be directly usable on other vehicle combinations, and it seemed more complicated than what I wanted to deal with. I'll try those tables, what behavior changes should I be looking for (good or bad)? If I need to scan anything, what PIDs would you want to see?
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
  9. #49
    Jan 2011
    Bella Vista, AR
    363
    I would think that the values I have spent weeks tuning for my motor would be closer to correct for heavily modified motors than the
    stock OEM tables. Transient fueling if correct will bring your tip-in and tip-out AFR closer to stoichiometric (14.7) all the time.
    It is possibly impossible to keep it spot on 14.7 all the time, however it should be very close. It will impact how stable your cold and
    warm idle is as well as how quickly your power enrichment AFR is reached and becomes stable. Throttle response becomes immediate
    when this is dialed in. There simply are no longer any perceivable rich or lean spikes any longer. If you had my set up and could either
    watch AFR at all times or watch the log of AFR at all times, this makes it very easy see how steady AFR is during throttle transitions.
  10. #50
    Nov 2002
    Central Florida
    2,503
    I would imagine that the intake manifold material and
    surface finish is a big deal here. I do not see declared,
    what kind of intake is on JL's "heavily modified motor"
    in all of this work.
    Having a not-all-that-popular aluminum intake myself,
    I wonder how close I could get by copying. Not that I
    think the stock values are bothering my drivability any.
  11. #51
    Jan 2011
    Bella Vista, AR
    363
    I revised above post with information about motor and latest tune file. The one I posted this morning was not the
    correct file. I had tried increasing the 100 MAP values for impact factor, however it appears that impact factor is
    essentially the same at 100 MAP and 80 MAP.
  12. #52
    Jul 2011
    Houston
    45
    I wanted to compare your file to a stock file to see what all you adjusted, wouldn't be allowed.
  13. #53
    Dec 2008
    on the Dyno
    1,825
    I've worked on these tables a bit on various platforms and generally I don't worry as much about the tip in as long as the tip in isn't lean. If I'm commanding .89 lambda at WOT and on the initial blip it spikes down to .79-.80 lambda I am fine with that as that little burst of extra fuel alot of times will give the car a snappy feel. It's when the tip in has a lean spike that you need to do some tweaking as that'll make it feel like it has a dead spot.
    One other tid bit that needs to be known is that the main fuel/VE table needs to be calibrated in steady state to the T before even bothering adjusting for transient fueling as that main VE value is still the base for fuel delivery with the transient settings just being a modifier to that. Sometimes this is hard to do without a dyno because initial WOT hits can occur low in the RPM range meaning a loaded dyno that can hold 1200rpm 1600rpm 2000rpm at WOT is about the only way to properly get the upper load/low rpm portions dialed in.
    Same thing for tip out, alot of tip out issues occur because the upper RPM full vacuum regions vary rarely get calibrated. A simple way to do this is to turn DFCO off do a WOT pull and let out of the gas and let the engine slowly come back down recording data. Adjust the full vacuum regions using this data and smooth then check tip out.
    Located in Central Kentucky
    ShorTuning
  14. #54
    Jan 2011
    Bella Vista, AR
    363
    Transient Tuning - The Final Chapter for Me
    Thanks for your advice James. In agreement with your comments, I see the primary problem trying to tune on the street
    is that transient fueling can cause bad lambda error readings because it interferes with one's attempt to obtain steady
    state readings, which to me is worse when calibrating the VE table than when calibrating the MAF table. I have managed
    to dial mine in pretty close now however it probably took me 20 tuning sessions or more whereas this could be done on the
    dyno with just a couple of runs. Once transient fueling is closer to accurate, this allows you to reach steady state much quicker
    when going back and fine tuning VE and MAF again on the street. For me, transient fueling errors at high MAP prevented me
    from dialing in a constant AFR during power enrichment, and once I nailed WOT transient fueling I was able to come back and
    calibrate the 8,000 Hertz and higher portion of the MAF curve much more accurately which then yields a very stable
    WOT AFR during power enrichment. I found transient fueling tuning on the street to involve a lot of trial and error to
    finally get it where I thought it would be very difficult to improve any further. I really wonder how applicable my transient
    fueling would be to other similar builds? My end results are posted here, where only a few boiling rates were changed
    from prior tune posted.
  15. #55
    Jan 2011
    Bella Vista, AR
    363
    You could make my changes to one of your actual tunes for your PCM, and then compare with stock file to see the differences.
    You should go ahead and try my transient table values since these will not affect the MAF and VE tables you have already
    tuned. Transient only affects what happens on tip in and tip out and you can see if your AFR stays closer to stoichiometric
    on tip in and tip out than it currently does. If your transient fueling should be very close to correct now, then you may not
    want to bother messing with this at all though. Like they say, if it ain't broke, then don't try to fix it.
    Quote Originally Posted by Mudweizer View Post
  16. #56
    Aug 2010
    215
    Great info guys!
    "Log IBPW at idle. For example, lets say your idle IBPW is 3.2ms
    Divide this value by 31.124308 this will give you 0.1028135. Place 0.10 in min fuel in mg."
    Does this still hold true? I'm seeing 1.5 IBPW, so does that mean I need to change my min fuel in mg to 0.048?
  17. #57
    Feb 2016
    Texas
    534
    A very old thread, but a very good thread lost to the ages of time. Bumping this thread as it has helped me a shit ton over the last couple days. Finally getting my transient issues figured out after battling with issues for months after an intake & injector swap on my vortec 5.7
  18. #58
    Oct 2004
    Orlando FL
    766
    I still don't understand the detailed workflow to dial in the transient fueling tables.
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
  19. #59
    very good info
  20. #60
    Oct 2008
    Mebane NC
    475
    While old this is very good info indeed.
    This is something I'm dealing with on my 383LT1 with 24X conversion using a 411/12212156 -> 1251002 2bar. Thus far all my tuning has been done with the supercharger belt off. My VE tuning was spot on in open loop with the WB except around idle which I attribute to the cam (224 - 236 @ .050, 1.6 Shaft Rockers) and long tube headers. Removed the WB installed the NB put it in closed loop had to make some minor changes to the VE table. After further driving I have this annoying lean condition while cruising at 50 -60 MPH and this almost bog sunsation during cold acceleration, idle surging when coming to a stop. When in open loop I dialed all that out of it, put it back into open loop and it was gone.
    My initial guess was that it was in the transients since LT1 intake is far different from LS intake but I hadn't gotten around to trying to tune these tables. Now I have something to refer to when adjusting... Thanks again
