Results 1 to 4 of 4
Thread: 05 GTO 5 Sec Non Idle Surging at Coast
    Sep 2013
    Space Coast Florida
    2
    I am running with no MAF sensor using a IAT relocate in my Varam CAI. I have the hood opened up and get cold air quickly. The tune is a 2Bar (2.5Bar?) SD. The tune seems pretty good except that when I am driving and push in the clutch to slow and/or coast, I get idle hunting for about 5-6 seconds and then the idle becomes stable once again. The only thing I can see from the log is that the TPS seems to fluctuate approx. 1-3% while not touching the pedal at all (frame 600-700 & 920-1020). Could this be the culprit?
    Attached is my tune as well as a log file. In the attached log file I ran WOT 1st thru 3rd and then a constant speed. Depressed the clutch and coasted (frame 600-700 & 920-1020).
    Any help would be greatly appreciated.
    05 GTO 6Sp Forged 11:1 404" w/TFS 225's, Varam CAI, Ported LS2 TB, Fast 102mm w/46# Injectors, Comp HUC/LSL 239/247 0.620/6.23 LSA114 112ICL, Kooks 1-3/4" LTs & 75 Shot Wet Kit w/Wide band.
    Sep 2013
    Space Coast Florida
    2
    Anybody Have some thoughts about this.
    I appreciate any help.
    could the Vararam be causing turbulent air over the MAF when the throttle closes?
    just a shot in the dark
    Sep 2011
    Jax, Fl
    216
    No maf. It looks like your idle airflow to me.
    2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
    L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
    JHP V2 I Powdercoated Black 18s I Kyne Splitter
    2001 GTP I Stock DD
