Results 1 to 20 of 25
Thread: Air Fuel Ratio and Transient Fueling parameters
    Oct 2007
    Crawfordville, FL
    2,412
    The highly requested stoich air/fuel ratio parameter has been added as well as 6 transient fuel tables. I have added it to a handful of Mustangs, and will have it in all Mustangs by the end of the week. Update to the latest 2.24 release to gain access.
    Eric Brooks
    HP Tuners, LLC
    Tuner Blown383's Avatar
    Sep 2011
    New Mexico
    157
    Thank you so much Eric! Add FPAF0A3 next please! Haha jk. Good work! Just a quick question, if the car is rich on tip-out, do you decrease the values in decel?
    2007 Ford Mustang GT/CS: RGR 322 3v - JPC Intake - Vortech YSi-B - Magnum T56 XL - Built 8.8 - Full Suspension
    2008 Ford Shelby GT500: VMP Gen 2 - ATI 15% - SCJ TB - Full Bassani Exhaust - Full Suspension - Upper Pulley - Meth Injection - JLT 127mm
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by Blown383 View Post
    Correct, and I will have it added in tomorrow most likely.
    Eric Brooks
    HP Tuners, LLC
    Sep 2010
    43
    The Day has come! Thank you Eric.
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by svtadam27 View Post
    You are most welcome!
    Eric Brooks
    HP Tuners, LLC
    Oct 2007
    Crawfordville, FL
    2,412
    Just finished FPAF0, so download the latest 2.24 release and you should see the new stuff.
    Eric Brooks
    HP Tuners, LLC
    Sep 2011
    New Mexico
    157
    Thank you so much Eric. Car is running better than ever.
    Jan 2011
    VENEZUELA
    126
    thanks god and hptuners i always told support to add transient fueling very very happy for blown engines
    only please datalog speed and need more pids
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by witchertorque View Post
    High speed logging and more parameters to log is my #1 priority.
    Sep 2011
    New Mexico
    157
    Quote Originally Posted by Eric@HPTuners View Post
    Hey Eric, Acceleration > Gain at Startup RPM Y-axis doesn't show the points or is editable. Also can you increase the MAP X-Axis limits from 31.875 to something like 64 or 128 under Transient Fuel. Inferred MAP on my car is maxing out this table. I suspect that could be an issue on high HP blower cars. Thanks!
    Oct 2007
    Crawfordville, FL
    2,412
    I fixed the Y-axis so it is now editable, and changed the max value to 64. Grab the latest 2.24 tomorrow.
    Eric Brooks
    HP Tuners, LLC
    Senior Tuner CCS86's Avatar
    Austin
    1,089
    Eric, can you offer any insight on how these accel/decel transient fuel gain are applied?
    Are they adders/subtractors?
    Does manifold volume impact their application?
    Do they control commanded equivalence, or are they actually modifying injected fuel mass to account for transient effects like evaporation rate?
    Jan 2018
    202
    i am interested too as to exactly what these tables do.
    i feel like that are modifiers to the rate of enrichment for CL accel outside of WOT
    Oct 2016
    Poland
    1,744
    Just IMHO:
    You have 2 parameters that controls the Transient. Intake manifold does not affect the Transient that much to be worried. Transient is more for engine and how good or bad the engine's VE is.
    You have a GAIN and CONSTANT for deccel and accel. You also have those for startup - startup tables will be used for specified amount of time(250 seconds mostly) and then it will switch to normal tables.
    Transient is TIME required to fill the cylinders with AF mixture since it's port injected. Direct injected engines use the transient tables as well but I'm not even sure why - they are tuned differently tho.
    Time constant is your amount - you may treat is as SECONDS.
    Gain is your amplification/multiplication - you may treat it as PULSE just like with injectors.
    Increase gain - more fuel will be added.
    Increase time and it will stay being added longer.
    I don't think you should really tune Transient in a stock engine - you may have to with build engine or with some serious changes to intake system.
    I really think most "tips" in fueling are caused by MAF or Speed Density - I'd would rather tune the Transport Delay before touching Transient tables.
    Austin
    1,089
    Just IMHO:
    I don't think you should really tune Transient is a stock engine - you may have to with build engine or with some serious changes to intake system.
    What is your approach to tuning transport delay? Maybe you could add your 0.02 here: https://forum.hptuners.com/showthrea...-Time-Constant
    From my testing, I have seen definite changes in the short tip-in / tip-out fueling errors when changing Manifold Volume and the Transient Gain tables. My biggest struggle at the moment, are long, slow swings in the STFTs, when everything else appears to be very stable:
    R6w-idle-FT-swing.hpl
    Austin
    1,089
    Yes, I am logging commanded vs measured.
    My current technique is to find steady periods within a certain RPM/load combination, then average the time distance shown here over a number of O2 cycles and use that to feed back into the transport delay tables. Are you doing something different?
    Oct 2016
    Poland
    1,744
    Nope, exactly this way. Just make sure to filter some random hits.
    Austin
    1,089
    I'm surprised it is so far off from the factory values. My exhaust is stock between the head and O2 sensors.
    Any thoughts on that log I posted? Those slow transient STFT swings are refusing to die.
    Oct 2016
    Poland
    1,744
    Have you tried switching the SD off?
