I was told that you could moniter the AFR's from the factory O2 sensor's, is this possible?? If so, how can I set it up?
Log the B1S1 O2 sensor, it's a wideband. LNF's need to be tuned in Lambda, not AFR. .88 PE Lambda is the sweet spot when WOT.
