I dont like paying someone for work that I can do. BUT with this tuning thing, I am a total noob. I am reading and researching and learning as much as I can before I pull the trigger and purchase.
To give perspective on what I am working with, I have a 98 Silverado and am in the process of doing an 01 LQ4 motor and 4L65E swap with a 411 PCM. ALL from the same donor vehicle. It is all stock either for now or I will find another LQ4 and build that one up.
I do have a couple of questions.
1: If I go into the PCM and change the Fans, VATS, Emissions & Gear Ratio, Will the stock, "OEM" tune if you will, stay in there? Basically get my truck started and driving like it would as if I didnt touch it other than disable features I dont need?
2: I saw how to change fan 2 pin, but can the fan 1 pin be activated on pin 42 on blue connector with HP?
Thanks in advance
