Hello guys,
Good day.
My car is a 99 Z28, with a 9.5:1 static compression ratio and forged 383ci, FAST 90/90, Headers 1 3/4 steped 1 7/8, AFR heads 66cc, and 10 psig of boost and all the coolers of course. One thing that is a importante factor, that I live at 8,000 feat over sea level. I am not an experienced PCM tuner, btw.
I have a problem with my car, which is driven /raced at the race track (road racing), and for that reason I have to be really carefull with the tune, due to the fact that at the track temps with FI get really high and detonation is a matter ot time if you are not carefull with the fuel and timing (as for sure, all of you know). I have a good friend that help me out, at the beginning, with a soft tune of the PCM where WOT races did not matter at all, because there was not knock retard at all... The problem came up, once I was at the "esses" where KR at 19% of the throttle was in minus 6 degrees, which tells you that mid throttle was not tuned properly, and there is where I am having problems.
I can tune up the car really nice once the PE mode gets in after 21% of the TB is engage. I tought that maybe lowering the PE mode to 14% might be a good call, but I drive my car to the race tracks (100 to 150 miles away), so I do not think that could be such a great idea. I have been reading that one with option is to tune up the MAF, which btw is scaled down, due to a suggestion of my tuner friend, but now, as I told you before, I am the one doing the work. I would like to have a good tip-in on the car, but unless I lower the PE mode engage, it sends KR that last from 2 to 3 seconds and ranges from 2 to 4 degrees. I have been trying to fix the car's problem and it dying coming to completed stop after high reving, even with the Throttle Follower function, and it does not work really well. Between the awful tip-in and dying after high revs and to complet stop, it is being a nightmare... Tip in mostly.
Guys, is there a way to richen up the fuel withouth the PE mode? Do I have to edit the MAF to do so? Engine dying after high revs and complete stop, how to?
Any help is going to be greatly appreciated.
Thanks in advance.
Rodolfo Lara P
