Results 1 to 20 of 25
Thread: Stock 05 Mustang GT
    Stock 05 Mustang GT
    New to Ford tuning. I know tuning a stock GM vehicle can add some HP. Is it the same for Ford or are they tuned aggressively form the factory?
    1968 Chevy C10 SWB - Project
    2018 Denali L5P
    all new vechile that are not special editions (factory race cars) can be improved
    97 k2500 ecsb 5.7l/4l80/4x4 0411 pcm,thorley tri-y's,true duals(no cats),msd ign.,zz4 cam, tuned with efi live
    Quote Originally Posted by Z06-Hammer View Post
    Yes of course. The WOT lamda is fairly rich, and the timing table isn't aggressive at all. If you're running 91/93 octane instead of 87 you can pickup a fair amount of power. I ran E85 on both of my N/A 3v's with very good luck. I'd stick a tank of good fuel in it, and throw some timing at it. the knock sensors in those cars are very accurate.
    Oct 2007
    Crawfordville, FL
    2,412
    A tune for 93 octane will generally gain 15 rwhp or so, but there are great improvements to throttle response, and transmission shifting.
    Thanks for the reply's! So it's the same as stock LS vehicles. Add a little timing and clean up the rich PE tables from the factory.
    Quote Originally Posted by Eric@HPTuners View Post
    Eric, I found your "How to tune you Mustang guide". Can I follow the steps from ETC Max throttle angle and on down? This is a daily driven car that I run 93 octane in and was just looking for a little more power.
    2018 Denali L5P
    Oct 2007
    Crawfordville, FL
    2,412
    Yes
    from stock GT with JLT110 I get constatly 40 HP at crank and lot of TQ down low.
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
    Quote Originally Posted by caniggia View Post
    Do the CAI's come with good MAF Airflow data or is this something I will have to log with scanner and my LM1?
    2018 Denali L5P
    log with scanner and lm1 then correct on youre own. even when they have data i still due this
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Transmission shifting? Still waiting for Hp Tuners to add the missing tables to firm up the shifts of the 5R55 transmission.
    Russ Kemp
    Oct 2007
    Crawfordville, FL
    2,412
    I have it on my to-do list near the top.
    Dec 2005
    Regina, Sask.
    4,214
    Thank-you. I have 2 Mustangs that are waiting for me to firm up the shifts.
    Russ Kemp
    In transmission topic i posted i have dump from firm shifting tune and same parameters entered to hpt, so you have exact compare so you can easy find missing tables. If it will help, let me know, i will send them to You
    www.hd-customs.pl
    28,268
    Eric already has the files you sent, but thank you
    Oct 2011
    QLD, Australia
    436
    Are those Mustangs you have fitted with the 6R80 transmission?
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by 45T-XR View Post
    The 2011+ Mustang has the 6R80.
    Oct 2011
    QLD, Australia
    436
    Do you guys support the 6r80 TCM? Both that and the aussie zf6hp26 fairly similar variants so surely it wouldnt that hard to sort the tcm here
    Oct 2007
    Crawfordville, FL
    2,412
    Not yet.
    Oct 2011
    QLD, Australia
    436
    Sounds like Hp have taken the right steps to get the ball rolling agressively with the fords..holefully the aussie ones too
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    I'm working on adding these now. Tell me the OS ID of the two cars you have there and get them done first, as it will take me a while to get it into every automatic Mustang OS.
    Eric Brooks
    HP Tuners, LLC
