No its fine dont worry. Everyone must start somewhere so I wouldnt feel embarrased to be labeled a tune beggar, its better you get something to reference than nothing at all. Either way if u plan on using the original file modify the airflow tables and you might need bigger injectors. Also the shift points were adjusted , well you will see the difference when you see my file.
Good luck
