Results 1 to 13 of 13
Thread: I have a couple issues I need help with.
    Jan 2005
    kitimat bc
    274
    I tried my hand at doing a boost pid but I think it reading double? And I also noticed that later in my drive I started showing negative LTFT's. Is my O2 looking ok or should I replace it?
    86 Fiero Convertible 3800sc/4T65E HD(2002)
    Jan 2005
    kitimat bc
    274
    I think I may have solved why my boost isn't reading properly. I was playing around with the layout and came across the user defined pids and through that, was able to input the function which I couldn't find before. I will have to give that a try but I still am wondering about the rich condition.
    Jan 2005
    kitimat bc
    274
    could someone look at my maf and O2 sensor to see if they need replacing? the car hunts for idle but when i disconnect the maf it clears up. i still get a reading in the maf.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Your not logging Maf Hz. And your not in closed loop (in post #3).
    Russ Kemp
    Jan 2005
    kitimat bc
    274
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Dunno? It's all stock right now I am just trying to get it all running properly. What should I do? I think the maf is on the way out, I know it's reading but II don't think correctly though. It's hunting for idle and will eventually stall, if I pull the maf then it's better.
    Jan 2005
    kitimat bc
    274
    Bump. I have since replaced the maf as it was failing, I am still wondering if the o2 is normal, it's still running rich.
    Jan 2005
    kitimat bc
    274
    Anyone on the o2 readings if they are normal or slow and on its way out?
    Dec 2005
    Regina, Sask.
    4,214
    You need to scan the car in CLOSED loop to see if the O2 is switching correctly. And you need to add the Maf Hz pid to your table, chart & histograms.
    Russ Kemp
    Jan 2005
    kitimat bc
    274
    Shouldn't it already be in closed loop? Or was the engine too cold still and was running in open? How do I tell what loop it's in?
    Jan 2005
    kitimat bc
    274
    bump.
    Oct 2013
    11
    Your engine only got to 91F. It will need to get to full operating temperature before you can really tell if the O2s are working well.
    Jan 2005
    kitimat bc
    274
    Quote Originally Posted by mdenz3 View Post
    Ok, I'v started another thread on the above. Any idears on the boost pid not reading correctly?
    Jan 2005
    kitimat bc
    274
    Bump.
