Results 1 to 5 of 5
Thread: tuning for e85
    Dec 2006
    Fort Lauderdale
    171
    tuning for e85
    Hi, probably going to convert my cts-v to e85. I tried searching the forum for e85 with no results. Can anyone point me to a guide of some sort, or a post already covering this? Or just a few pointers on which tables i need to pay attention to? I have plenty of tuning experience, just never used e85 and want to make sure I change all the tables necessary. I know I will need to adjust for more fuel, but want to see if there is anything in particular I need to do.
    Thank You
    2001 Z06 - Blown (Sold )
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    You will need to change the stoich value then add timing to suit. Cranking fueling needs to be upped as well by 25-50%. I have a CTS-V dual pump in mine (Livernois) so fueling will be close on yours but your injectors will likely be too small. I see pressure drops to 44 psi at WOT with 58 psi commanded at 9 psi boost but the ID850 tables seem to compensate well as it is consistent.
    What injectors are you running? I see 80ish % IDC on ID 850's at .77 lambda PE.
    E85 requires ~30% more fuel than E10. Get a WB and learn to tune Lambda, forget AFR.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Do it right. Get a sensor.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Tuner in Training b2319dragracer's Avatar
    Jul 2013
    Dundalk, Maryland
    25
    Can you command more fuel pressure?
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Quote Originally Posted by boostls2 View Post
    Thank You
    Hit me up at shop this week.....if your in Lauderdale we are right up the road.....
    HT
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
