Results 1 to 5 of 5
Thread: Switched to E85, changed stoich value and VE way off?
    Sep 2009
    10
    I drive a turbo'd 2006 Silverado WT 4.8L non flex fuel. I filled up with e85 last night, with only a few gallons of gasoline left in the tank, I drove for a few minutes to maybe get some of the gas outta the rails. Then uploaded a tune, I changed the values in all cells of the stoich table to 9.8 for e85. It started rough but I drove for a little while (10 miles maybe) and it stayed rich, and I had to take out 20% from the VE to get to lambda while driving. I ended up driving for over 40 minutes. The gas tune was pretty spot on. This morning the cold start was super lean, and just a little lean crusing, man am I confused, I thought all fueling would be adjusted to the change in stoich?
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by MustangPunk View Post
    I have not converted a GM vehicle over to Flex Fuel, but have done a lot of Fords, and the same things happens with them. Re-adjusting the VE table is probably the easy way out. I believe the injector values are probably the reason for this.
    Eric Brooks
    HP Tuners, LLC
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Check your fuel pressure, E85 requires ~30% more fuel so if your pressure is tanking, the IDC climbs and you are going to need to retune.
    '12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
    Advanced Tuner sarg's Avatar
    Aug 2011
    Atlanta, GA
    305
    Did you check the actual percent of ethanol?
    Dec 2008
    Anderson, SC
    198
    OP, you can get a "flex fuel sensor" (oem ones work fine) and a gauge/module to display the ethanol content of your gas. Make sure you get one with outputs, so you can log ethanol percentage in HPTuners. I think you could also just use the sensor if you just wanted to pipe the voltage directly to HP Tuners.
    http://www.zeitronix.com/Products/ECA/ECA.shtml
