Results 1 to 4 of 4
Thread: surging when rolling with throttle closed
    Dec 2012
    4
    this is so damn annoying. my idle isnt the best in the world, i still have to tweak it a little but it idles pretty good. then i go to coast down my driveway(throttle closed) and it just keeps surging up and down, fixes itself once i come to a complete stop. also doesn't do this above about 30-35 mph. does anybody know what tables to adjust? throttle cracker/follower? log, config, tune is attached. you can see it right at the very beginning of the log. it's a 5.3 with a fairly small cam in it
    Dec 2012
    4
    anybody have any idea?
    Advanced Tuner printmanjackson's Avatar
    Nov 2009
    USA
    412
    surging is usually from being too rich
    '02 Corvette
    LS6, MN6, LT's/X pipe and TI's, Honker CAI, AI 243 heads, PatG Custom Cam, FAST 102, LS2 TB, Red Top inj, HPTuners & NGK/AFX
    Dec 2012
    7
    Your Base Running Airflow(Idle Airflow) values are larger than needed based on you engine size and Target Idle speed. Look at stickies for Tuning Base Airflow guide. Also under Idle/Airflow, Throttle Cracker your Disable Speed should be lower than your Enable Speed. You can look at lowering some values in Idle/Airflow, Adaptive Idle Airflow 4.50g/sec maybe too much if you have a larger cam.
