Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: LSJ ID1000 setup.
    Jun 2013
    22
    LSJ ID1000 setup.
    I copied the offsets based on averages of the appropriate tables since there is no LSJ ID1K table on their website. Does anyone have a working example of a dialed in ID1000 set of tables? I am having a bit of stumble with low speed 1 to 2 shifts and clutch engagements I think is related to how quick these injectors are, and running e85. You can email it to me [email protected]
    Jun 2012
    Pensacola, FL
    150
    Give me a day or so and I will make the data for you.
    But one question...did you have to reduce your maf tabe quite a bit to even get it to idle? As in were your fuel trims very rich at first?
    Jun 2013
    22
    Thanks, he will be here in a few hours so I will try it. I've got a smooth idling, powerful but safe tune right now that has this low vacuum low rpm stumble from a fuel dump or something...
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Contact Injector Dynamics. They will put the data in your format if you request it.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2013
    22
    I did just that, and it was in my email. Problem solved, fuel loading was an issue, too much offset. I guess for those it concerns these are some wicked fast injectors.
    Jun 2012
    Pensacola, FL
    150
    Quote Originally Posted by army_greywolf View Post
    How much offset did you have to remove?
    Jun 2013
    22
    almost a third of a ms in the area i was having trouble with, 1.4 to 2.2k rpm/low vacuum killed the stumble as soon as i loaded it in i still say despite being injectors that are big and running 4 bar vacuum regulated return, it's a damn nice injector
    Jun 2012
    Pensacola, FL
    150
    you are the 3rd person i know now that had to cut the offset values. This verifies my findings even more. This damn P12 computer is a pain in the ass.....
    Now take the offset tables you had before you cut em, and divide them in half. Bet it will be damn close.
    Mar 2008
    St. Louis, MO
    4,859
    He got the data straight from ID and didn't have to edit that...
    Apr 2007
    1,104
    The tables that Paul Yaw and myself developed for the lsj and the 1d1k's was halved for a resolution reason. We spent the better part of two weeks going back and forth on the scaling to work in the ecm. The tables that he supplies for the ecm work fine.
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
    Jun 2012
    Pensacola, FL
    150
    Quote Originally Posted by Area47 View Post
    wait.....so the same basic offset you would use in say an E67, 0411, etc you had to cut in half to make it work on the LSJ? Because thats what i have found with 6 different injectors in the P12 ECM so far. I was unaware that this was already accounted for in the data provided by ID for the LSJ.
    Apr 2007
    1,104
    You either need to email him directly, or tony at t1 directly to get the tables for the lsj.
    Jun 2013
    22
    Let me clarify. I got the LSJ tables from ID emailed to me. It was almost spot on, BUT there you have it, low end stumble, the only way to cure it is to take out offset. I suspect that the higher overall pressure (58 at atmosperic on a return system) is making things a bit faster, I am not exactly sure on that since I haven't seen an ID1000 broke down to look at the nozzle and so forth. Also, when you test everything during installation, it would do you good to offset the whole table by .5 volts, the reported voltage system voltage was 14.3 while the actual voltage at the injector was 13.77. I went ahead and moved the entire table up by one and guess what, just that tiny little bit of midrange that bothered me a little smoothed itself out. Small changes make noticeable differences here, which tells me the dial in needs to happen here and with the other injector tables before you even THINK about VE tuning... After all wrong offset and it'll wash the valves and pool fuel leading to unwanted popping and skewed values on your trims. Big injectors need the precision right? Anyways, take out .22 ms in the 13.5 and 14v from bottom to 81...not necessary beyond that i think.
    Dec 2008
    Nevada
    4,452
    Still need to perform a ve swing test to be sure
    Jun 2013
    22
    I've tried over and unders already in the stumbling areas, that wasn't the issue, it was the FIRST thing I did actually.
    Apr 2007
    1,104
    did you put a second set of o-rings on the body of the injector to keep them from pushing through the insulators?
    Jun 2013
    22
    What? Can you show me an example, this is a customer build so I am not picturing what your talking about. I fixed the problem anyways, but I'd still like to see what your referring to.
    Dec 2008
    Nevada
    4,452
    lsj intake manifold has injector cups to fit the injectors properly to the head. if you dont put a second larger OD oring on before you install the sealing oring for the lower injector seal the injector will eventually get sucked into the intake manifold and cause vacuum leaks or fuel leaks.
    http://www.crateenginedepot.com/24-I...17420C693.aspx
    the cups have their own seals to the head your just installing 2 on the injectors nozzle side
    Nov 2009
    Cumming GA
    49
    This is what he is referring too. The 2nd set of O-ring that are to be used on these injectors.
