Have a 2011 CTS-V with henessy blower. Everything is tuned perfect but when in a turn or very low speed WOT acceleration, it dips into the low rpm high airmass section of the timing table and it is like -20 degrees timing and the car stubmles for a couple seconds and then starts to make power. This is pronounced during a hard turn. I disabled burst knock under 3000rpm but it did not seem to fix the issue. I also added 20* timing to the idle spark, high and low octane tables just as a test, in all of the 400rpm to 2000rpm cells and it still -20 degrees at like 600 to 1000 rpm.
I believe that if I could get it to add some timing, it would not have this hesitation. Also note that any traction control is turned off.
Any ideas?
scan.hpl
base-noburst.hpt
