Results 1 to 6 of 6
Thread: PLX EGT via EIO Input
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    646
    Just curious if anyone else has logged EGT through the EIO. I can fudge the calculation and have it appear 1/10 or 1/100 of the actual figure, but was curious if there's a workaround for this?
    The linear for Fahrenheit comes out to V / .00185 + 32
    HPTuners only allows three decimal places for the voltage calculation, so I'm kinda screwed there
    '20 AT4
    '01 Suburban 2500 Dad Wagon
    Oct 2006
    Houston, TX
    646
    Attached is the linear output image from their manual.
    '20 AT4
    Tuner seven ends's Avatar
    May 2007
    Houston, Tx
    155
    Suggestion: plug .0028 and 273 into the user-defined inputs to start and see you a very close workable scale in Kelvin and then tweak from there. You can always convert back to Celsius or Farenheit once you can log it.
    Last edited by seven ends; 08-15-2013 at 07:09 AM. Reason: Typo on value corrected
    2010 Avalanche 4WD; AES 390; Mast LS3 heads; VVT Cam; ported TVS2300; Overdrive 8 rib pulleys; 2.7 snout pulley; ID1000; LS3 TB; WB 450; Twin MM cans; built 6L80; CircleD Triple Disk, CSR flexplate; Trucool 40K; Aeroforce Dual; AFX
    Oct 2006
    Houston, TX
    646
    I'll give that a try and probably just make a custom histo/PID to convert to fahrenheit. It's one of those things that I'll unrealistically be looking at the EGT gauge while making a hit, but want the data for nitrous/FI. Thanks for the input
    '20 AT4
    May 2007
    Houston, Tx
    155
    Sorry for missing the point.....if I would have tried it I would have realized that Celsius works great too if not better...... .0033 and zero......cheers
    Dec 2008
    on the Dyno
    1,825
    Use the list view instead of the transfer function. I do this for my wideband calibration in lambda as well because the equation doesn't allow enough resolution in decimal places.
    To make it simpler you can erase the entire list and re-write it like this:
    0.00,xx.xxx
    5.00,xx.xxx
    Once you input the parameters it will automatically populate the graph to the right of the list and you are setup at that point.
    Located in Central Kentucky
    ShorTuning
