2006 z06 28k
PRC 265 Heads 390cfm, milled .020
TSP LS7R Cam 248/256 .622/.648 114+3
Halltech MF103 Superbee
Ported Intake and TB by Peak Performance
Pfadt 1-7/8 Headers, No-CATS
New GM MAF
ZR1 Injectors 56.4lb
ATI Underdrive pulley
(Stock Mufflers)
8-3-13 Dyno 562hp/496tq
3-2-13 Stock dyno 433hp with a old Halltech Killerbee and Jet Performance MAF
After a dyno tune 456hp with airbox and MAF.
The same day I dynoed stock, a 2009 Z06 with 11k dynoed 460hp bone stock. The dyno shop said mine was the lowest he had seen come through his shop. It was not what I wanted to hear, but I accepted it. I went home and did a compression test and the cylinders.
1-193 2-195
3-193 4-198
5-200 6-197
7-193 8-200
The issue= With all the new mods it only dynoed 562hp/496tq. I was expecting at least 575hp but it was down on power so I added the pulley , milled the heads , and ported the intake and tb.
My data log shows over 100 g/cyl airmass above 3,800rpm, even 120g/cyl at 5,600rpm.. My tuner said he had not seen a car run over 100g/cyl unless it had forced induction on it.
Why would it run over 100 g/cyl on my car and not other Z06's?
The MAF is getting close to maxing out so we were going to adjust that this weekend it is 9,100hz and I'm out of adjustment at 9,800hz.
Looking for answers, Im not a master tuner but trying to learn my setup.
https://www.dropbox.com/s/erosuvm40g...am%20B-Rad.hpt
https://www.dropbox.com/s/o23fx0u7g8...0new%20MAF.hpl
